C4 pressurised brake bleeder.
Hi any recommendation on pressurised brake bleeders for c4. I see on a lot of threads people recommend motive bleeder but they are not available in the uk. Thanks in advance.
Build your own! I did. Lawn sprayer, pressure gauge to 30 psi, and a Doorman reservoir cap. I also bought a swivel to allow for threading the cap on and off without twisting up the hose. Total cost of about $40.
I've got this one: http://www.ebay.co.uk/itm/Motive-Pro...0abb3#shpCntId
Been awesome so far. Looks like they ship to the UK
I bought a Motive bleeder directly from their US website, it was delivered to Norway in 5-6 days. Bleeding is a breeze with it using the procedure description in the 993 Bentley manual.
Cheers,
Tore
Cheers,
Tore
C4's. DIY here: https://rennlist.com/forums/964-foru...procedure.html
You can bleed the 964 brakes fine with vacuum, I have done on my car many times.
I also have a gunson pressure bleeder (readily available in the UK) which I've used when I wanted a bit more oof eg if the system was fully dry.
I however recently changed my views a little and on very old systems I think pressure bleed is safer on old potentially worn out seals than vacuum - I recently had an old ABS unit (not in the 964) spring a leak after vacuum bleeding and I think it's because the old seals could hold the pressure (which they see all the time of course) but not the vacuum.
The 4wd stuff in the frunk can be bled without any special tools (no vacuum or pressure equipment since it supplies it's own pressure) you just need to fully the procedure in Adrian's book. The 4wd locks can be done with or without the bosch "hammer". I have only done them "without", you just have to pressurize the locks but using the **** in the centre console and then crack the bleed nipple, and repeat many times.
+1 ^^^ exactly the way I've done mine. I use pressure from my air tool compressor with some tubing and a modified rubber maid cap that happens to fit perfectly on the brake fluid reservoir and also use the **** in the center console method for the diff locks. No need for any special bleeder or diagnostic tools.
The thing to watch out for on the C4 if not using a wet pressure bleeder like the motive, is that when you bleed things like the bomb in the frunk, you can empty the reservoir quickly and introduce air to the system if you aren't watching. Outside that, bleeding the system, while easier w the right tools, can be done as described above with zero issue.
