Why no interest in LED headlamps?
#151
Technical Guru
If these bulbs somehow work-around the existing problems then I will be first on the list to buy them.
#154
Ok. This is the UK beam pattern produced by the H4 headlamp and is what is required to pass the MOT inspection. The Euro pattern would be reversed L to R. Would this pattern be acceptable in CONUS?
#155
I wish I had a 964 close by to help out with the questions at the moment. I will see if any or our customers have taken a photo up against a wall that they can send over to me to help answer you questions.
Steve
woodypeck CREE LED Bulbs
#156
looks like superbrightLEDs have started carrying headlight bulbs
https://www.superbrightleds.com/cat/...nversion-kits/
#157
Thanks Harry for the excellent detail image. That is correct as you say for us in the UK. That is what all cars have to pass with the output from their lights - 964, 928 or otherwise it is not car dependant.
Steve
Steve
#158
#159
The idea of the Copper Heat Braid instead of the fans is a brilliant idea and ideal for the 911's with little room in the headlight bowl behind the bulb. We have been in contact with this factory to see if they can rotate their bulb chips 90° so they are aligned in the correct direction for H4 bulbs & reflectors. We will keep you posted
For reference: On this site the bulbs they show are an early version. The latest version is 35watt not 20 watt as sold on this web site. Also the latest version has 3000 lumens whereas this website only sell the 1300 lumen bulb! Significant difference.
Just so Forum members understand what is being shown here. The bulbs chips are placed so they shine left & right instead of up & down in line with our H4 reflectors
Steve
#160
My Neighbour was taking their Shogun 4X4 in for an MOT Road Test this morning so I asked if I could put on one of our H4 CREE LED bulbs in his Headlights as he went for the test.
We only had the 4300 Kelvin bulbs left in stock as we are now sold out until the delivery next week but here are the photos as promised of the bulb reflection image through the MOT Test centre optics as required by UK law.
The car passed with no problems and great praise as usual for our CREE LED bulbs! [ But our Neighbour's headlight was out of alignment & needed to be raised a little as can be seen - but that was nothing to do with our LED bulbs.]
G5 CREE H4 4300K MOT from today's MOT test in the UK of a neighbour's Shogun 4X4 - image A<br/>With the test Optics slightly out of line to show how the reflector pattern works with the kick on Right Hand drive car headlights.<br/><br/>These Headlights do need raising but that is nothing to do with the CREE LED bulbs - juts a neighbours shogun that I loaned for the test.
G5 CREE H4 4300K MOT- from today's MOT test in the UK of a neighbours shogun 4x4 - image B<br/>With the optics in-line to show the correct bulb light pattern and the kick to the left-pavement-side for Right Hand drive UK cars<br/><br/>These Headlights do need raising but that is nothing to do with the CREE LED bulbs - juts a neighbours shogun that I loaned for the test.
Steve
Woodypeck CREE LED bulbs
www.woodypeck.com
Steve
www.woodypeck.com
#161
The CREE LED bulbs in my 928 exactly match & replicate the standard Halogen bulb which they replaced.
That, my friend, is an entire impossibility, halogen and HID bulbs both have a spherical light source, the flat plane of an LED chip CANNOT provide that, EVER!
The light cut-off and reflector work in exactly the same way and give out exactly the same pattern on a wall, on a road & anywhere in the world I drive. Exactly the same!
You're dreaming!
Our bulbs H4 or H7 will replicate the same pattern as your standard H4 or H7 though the same Headlight lens. The pattern cut-off will be the same as this comes from the reflector and lens not the bulb.
Our bulb is designed to replicate the H4 bulb direction of light exactly.
You cannot possibly believe this to be a true statement.
And does a perfect job of this no matter where in the world you are. H4 for H4 identical design plain and simple.
Our H4 CREE LED bulbs are an exact replacement for a standard H4 halogen bulb. Like for like. The same pattern is for both as the pattern comes from the reflector and the lens.
You're dreaming!
#162
OFF ROAD USE ONLY.
We can be certain sure that each and every HID retrofit I have done, 8-12 maybe, are technically ILLEGAL.
But with EVERY one I have done I verified that the low beam high cutoff was properly positioned and as distinct/sharp as the OEM.
I don't see how that could be done as well with the thermal and physical mounting restrictions of LED chips but I remain open to seeing proof, but from the Horse's mouth, not some other source.
#163
Steve
www.woodypeck.com
Steve
www.woodypeck.com
In the US with the advent of the wide adoption of much brighter HID bulbs the issue if low beam high cutoff being sharp/distinct has become more prevalent.
#164
What an absolute load of twoddle! Honestly!
..."In the US.......adoption of Much brighter HID bulbs"..... are you for real! Come on!
How pretentious!
None of your comments, derogatory or otherwise, warrant any kind of response on here!
