Stand alone ECU project
#76
Great thread. Bought an AEM box but would certainly prefer a stand alone that is truly set up for the 964. Was talking to a guy name David Hampshire at a company call Canems in the UK (http://www.canems.co.uk/), who has a standalone ECU for the 3.2 and was planning to build one for the 3.6, but seems like he has put it on whole. Certainly, will follow along as I am putting my low boost turbo back together and need a Stand alone ECU.
biggles
biggles
#77
This is all a bit over my head, but having read through the whole thread some of it's starting to come clear in my mind and looking forward to see how the project develops Alex.
Hope to see you sometime and discuss it further.
#78
biggles
biggles
The AEM looks well specced but i have come across a few people that couldnt get them working right and the AEM o2/boost gauge that i have isn't the most confidence inspiring bit of electronic engineering i have seen. Their tech support didnt seem to think it was an issue that the voltage output drifted arround even though they suggest using it as an input to their ecus. I have also seen a few for sale s/h which you dont see much for standalone ecus.
#79
Hi AlexJC4, I'm posting on behalf of Fuch he asked me to stop by and I have been reading your thread, have you got this ECU fitted and running on a base map yet?, i'm an engine tuner by trade and have mapped quite a few standalone systems including Motec, Gems, DTA, MBE etc. this system looks very capable and good value for the money, if I can help at all feel free to ask me anything :-)
Chris Todd.
Chris Todd.
#80
Chris Todd.
Chris Todd.
The ECU is being assembled and tested on a 964 in Estonia as I type. So hopefully will be with me in the next week or two.
I am quite excited to get it fitted and running. Hopefully it should be fairly straight forward to get the car running OK on the base map. But just in case I've taken the last week off work in August to play with it
PS Are you the same Chris Todd with the bonkers 11 second rear engined Fiesta?
#82
Hi Chris, thanks for posting, I'll definitely take you up on the offer of some help/advice when the time comes
#84
The AEM device I have is this one. Great concept, and does basically what it's supposed to but I wouldn't want to rely on its outputs to actually do anything useful/important with...
http://www.aemelectronics.com/?q=pro...failsafe-gauge
#85
Would you mind explaining a little more about these two step:
1) Fit an analog/potentiometer TPS
Have you identified the part you'll need and how to mount it?
2) Remove AFM and add a separate MAT.
MAT ? the abbreviation escapes me at the mo..
#86
2) the AFM (barn door airflow meter) has a built in air intake temp sensor, if you go to speed/density you don't need the flow meter but you do still need a temp sensor. Normally I'd call it AIT tbh but the VEMS documentation generally calls it (manifold air temp) or MAT - they are fairly generic sensors but you ideally need to know the resistance vs voltage curve. I bought one that comes with a calibration chart from EFI-parts.co.uk.
#88
lol no I hadn't heard MAT used for AIT/IAT myself until I started reading VEMS documentation and community discussions. I think it's a European term.
While we're doing TLAs, here's a small aside on MAF vs AFM:
Bosch call AFM (barn door) type meters "Pitot-tube flowmeters" and call MAF (tube) type meters "hot film air-mass meters". I understand that there is a subtle difference in what they measure: air flow rate (AFM) vs air-mass flow rate (MAF). MAF is used on the 993 and continues to be the standard for production engine management systems, sometimes combined with MAP sensor sometimes on its own.
#89
I thought it was a terminology thing from different countries as well, too funny.
My car just went in to the shop to remove my AFM and convert it to a MAF.
Hoping to have my car back tomorrow by days end.
Jeff
Jeff
