964 Forum 1989-1994
Anyone running KWs with Rennline camber plates
Old 04-27-2014, 08:50 PM
9six4
9six4's Avatar
Default Anyone running KWs with Rennline camber plates
I've just got my new KW struts mounted with Rennline camber plates, but I'm not sure about the fit. I'm using the Rennline supplied KW specific nut and washers, but I end up with about 6mm of threads exposed on the nut. The nut is 26mm deep, so I have 20mm of thread contact, but it doesn't seem right. There is also no way of holding the strut rod to torque the nut. I don't really want to use an impact gun.
Thanks for any input.
Old 04-28-2014, 02:46 AM
964russ
964russ's Avatar
Ive allways used an impact gun to tighten top mount nut.
Old 04-28-2014, 08:11 AM
9six4
9six4's Avatar
I've used an impact gun previously on other setups, but I want to ensure that I'm installing this correctly first.
Old 04-28-2014, 08:38 AM
Vandit
Vandit's Avatar
Have you contacted Rennline? They're usually quick to respond.
Old 04-28-2014, 08:50 AM
9six4
9six4's Avatar
Thanks, I've been in contact with Rennline. I'm just curious about other Rennlister's experiences with installing them. I've noticed a similar thread exposure in other pictures and wondered if there were any issues.
Old 04-28-2014, 08:42 PM
9six4
9six4's Avatar
Well it seems that the Rennline camber plates work for KW V1/3, but the clubsports are different. Still waiting for information from KW and Rennline on how to proceed. The Rennline camber plates had a special top nut created on the recommendation of Singer who uses them with their KW V3 equipped base models.
Old 06-04-2014, 08:37 AM
9six4
9six4's Avatar
Default Resolved
I resolved the issues I had with the fitment of the KW Clubsports with the Rennline camber plate. I didn't run the spacer washer and Rennline machined the top mount nuts to allow access to the 10mm strut top. Seems to be some differences in the length of the top rod on different versions of the KWs.
Nuts machined down.
Lots of room now for the socket.
Name:  KW-Rennline top mount - New Nuts.jpg
My newly acquired pass through socket.
Name:  KW-Rennline top mount - Socket.jpg
Old 06-04-2014, 01:12 PM
Vandit
Vandit's Avatar
That drastically reduces the nut's contact patch w/ the socket, correct? Any concern about that?
So you're running the C2 clubsports or the Carrera RS clubsports? What is your ride height like, since running those monoball top mounts is supposed to result in a higher ride height compare to the standard mounts, given equal spring perch settings.
Old 06-04-2014, 06:45 PM
9six4
9six4's Avatar
C2 Clubsports. I didn't even know about RS Clubsports option until a fellow Rlister send a photo of his with way more threads. I'm hoping this isn't going to cost me more than the aggravation of time spent resolving the issue. I'm running at RS ride height and the helper springs are loose on the jack and compressed when on the ground. I'm not really planning on going any lower so it works for now.
The socket grips the nut and I'm torquing the 10mm strut so it isn't an issue.
Quick Reply: Anyone running KWs with Rennline camber plates
