964 Forum 1989-1994
Power steering fluid leaking...
Old 10-11-2014, 05:07 PM
  #31
HiWind
HiWind's Avatar
Nicely done ... That leak gets down to valve covers too ... Lots of dividends from that simple effort
Old 10-11-2014, 06:50 PM
  #32
greg1990964
greg1990964's Avatar
Originally Posted by RicardoD
Woohoo, my leak is the low pressure line #16, easy fix. I ordered a new hose from pelican for $13, probably just need to tighten the one end clamp
Got lucky!
Mine leaks on pistons so I am most likely going to have to swap it with my unit I have in stock. Will try Lucas stop leak to buy me more time.
Old 10-11-2014, 08:04 PM
  #33
Mr.Alex
Mr.Alex's Avatar
Ricardo, you got that OEM+ brand one? I also need to swap that one, got a bit more leaky as of late. Let me know how the fitment it, because 13$ is far better than 52$ for Porsche brand.
Old 10-12-2014, 03:22 PM
  #34
RicardoD
RicardoD's Avatar
I went with the $13 Pelican one, not the OEM one which is $40 at Sunset. I will let you know how it goes.
Old 10-12-2014, 06:22 PM
  #35
RicardoD
RicardoD's Avatar
I didn't realize the screw clamp on the pump inlet has a hard stop. You can't tighten it down any further. So a new hose is the right way to fix this. Its on its way from Pelican.
Old 10-16-2014, 03:42 AM
  #36
RicardoD
RicardoD's Avatar
Got the replacement hose from Pelican today. I need to check if I have the right size oetiker clamp on the reservoir side before I swap out the hose. Not sure what unobtanium material the factory replacement part is made out of, but this $13 one should do the trick.
Old 10-24-2014, 11:35 PM
  #37
RicardoD
RicardoD's Avatar
I fixed my leak via replacing the hose and the Oetiker clamp on the reservoir side. For the perfectionists out there the right Oetiker clamp that I used is marked 24.1 (which means max range of 24.1). That fit perfectly over the unclamped hose. I get my clamps through McMaster-Carr in the USA. McMaster part number: 52545K28
You can see my old hose was marked July 1990. After 24 years it has stiffened up considerably and can't be re-used and make a good seal. I will have to do the same on my C4 when I get to overhauling that one. I have 24 more Oetiker clamps left for this hose!!!
Old 10-24-2014, 11:37 PM
  #38
greg1990964
That is being **** perfectionist! Hose clamp would of been my solution. I applaud the effort.
Old 10-24-2014, 11:39 PM
  #39
RicardoD
RicardoD's Avatar
I am slowly building up my collection of Oetiker clamps. I see on eBay you can buy a whole automotive Oetiker set with the clamps of various sizes and the clamp tool for not too much money. I am buying mine 25 packs at a time and sometimes I have to buy two different sizes hoping one of the two will be perfect. Urgh.
Old 10-26-2014, 12:26 PM
  #40
-nick
-nick's Avatar
A little more expensive, but you don't have to buy two dozen at a time-
https://www.belmetric.com/metric-clamps-c-15.html
They have high-pressure Oetiker clamps too.
Old 10-26-2014, 01:26 PM
  #41
RicardoD
RicardoD's Avatar
Thanks Nick for the better source for these clamps! I will definitely be using then next time
Quick Reply: Power steering fluid leaking...
