Porsche Classic motor oil
#61
As we don't know what it is, we can't judge it.
Some lab testing would be nice.
Personally, I'm happy with the option. At least I know someone has oil that isn't meant for the water pumpers.
Now as to why Porsche uses the 10w60 for the 73 onward 911s? Who knows, but it's thinner at the bottom than our beloved 20w50 or their own alternative thickness and that's not a bad thing for mechanical components.
Now, I would like to know where the oil comes from though. Motul, Pentosin, Liquimoly (spelling)... they all make supposedly good oil.
For me, after I pay for shipping, it all costs about the same. Only the 10w50 from Mobil 1 is an oil that is readily available that I would consider. And since my stash of BP is only good for 3 more oil changes, I've got some decisions to make soon.
#62
As we don't know what it is, we can't judge it. Some lab testing would be nice. Personally, I'm happy with the option. At least I know someone has oil that isn't meant for the water pumpers. Now as to why Porsche uses the 10w60 for the 73 onward 911s? Who knows, but it's thinner at the bottom than our beloved 20w50 or their own alternative thickness and that's not a bad thing for mechanical components. Now, I would like to know where the oil comes from though. Motul, Pentosin, Liquimoly (spelling)... they all make supposedly good oil. For me, after I pay for shipping, it all costs about the same. Only the 10w50 from Mobil 1 is an oil that is readily available that I would consider. And since my stash of BP is only good for 3 more oil changes, I've got some decisions to make soon.
#63
If anyone cares to send me a sample I'll spring to have a virgin oil analysis done on it; at least then we'll have an idea of exactly what Porsche think is the right concentration of this, that, and the other thing.
Need about 2oz (unused!) in a clean inert sample container.
They have plenty of blurb on this and yes, at 60(!) I would have thought it thicker at high temps than we would normally need - almost definitely, surely. Allegedly there are other additives included that considers typical winter layup's and short intermittent journeys etc. just right for aircooled blah blah.. but who knows.
http://www.motoringresearch.com/news...ars-0617944581
I need more convincing and at £65 plus delivery for 5L from Design911 it can stay on their shelf. I'll stick with Mobil 1 10W-40.
Nice can but for a lowly £2.45 you can have the engine classic oil sticker instead.
#64
Sorry to come in as an outsider, but this oil created a bit of a stir in the BMW motorcycle community. I was following this thread for awhile to see if anyone got any results, but couldn't find any anywhere. Because of this, I actually did wind up getting some testing done, the testing was comparing it to a BMW oil, but you'll be able to see the lab results. Hope they prove helpful.
Part 1 - Getting the testing done
http://symphonyofshrapnel.blogspot.c...-20w50-vs.html
Part 2 - Lab results
#65
I am really surprised that Zn and P contents are below 1000 ppm in the Porsche Classic 20w50 oil
#66
Looking through all the said tests and results above (and opinions and experiences too) I've decided to go for Millers Oils CFS 10W-50NT. Had a really good email convo with their tech guy around ZDDP and the various data sheets. Developed for larger performance engines of fast/hard road (and light track) use with apparently excellent metal coating properties for that important engine start and warm up. I did raise my old school concerns about fully-synth and high detergent content 'stripping' away too quickly the carbon deposits from the years of semi-synth use. His response confirmed really that it's not a problem at all with the new oils of today with their coating and high protection properties. Apparently there is such a wide mineral window from producer to producer of what is available and sold as semi-synth that you never properly know what you're getting anyway - I suppose obvious when you think about it...
All in it's about £48 / 5L. Plan on doing an oil service next week so will give it a go.
#68
A virgin oil analysis (VOA) really tells us nothing more then what that specific test can see in the oil...Many additives may not even show up...The only true test is a very long and methodical series of Used Oil Analysis (UAO). The rest of most of these oil discussions is all conjecture and opinion. Pick an oil based on your intended use, change it at a reasonable interval. BP, Redline, Motul, Millers, etc. are all fine oils. I have used and tested almost all of them. You would be hard pressed to find any engine failures that could be blamed on the oil these days if you use the proper oil for your intended use.
#70
Well I'm sticking to 10W60 Mobil 1, which has a high ZDDP content (1300 Parts Per Million) than the 10W60 Porsche classic oil (883 PPM).
As for viscosity well that's a personal preference according to use. But for my use I ain't running anything below 10W...
#71
After all the conjecture, oil facts and individual experiences I've decided to go with Millers Oils CFS 10W50 NT. I found the email responsiveness from Millers tech support to questions and queries excellent and really helpful. Mentioned all sorts of oil requirements and ZDDP content etc and his recommendation match is the one I shall be using this week (after first cleaning up some of the filter to engine pipe leaks!).
#72
Have you seen any comparison btw Mobil 1 in Europe vs Mobil 1 in the states? I was searching and couldn't find any real info. I wood imagine they would have changed the formula and just made that their new oil, but who knows. Maybe they are two different oils...?
#73
RL Technical Advisor
Just take careful note of many European oils which are now API-SM & API-SN rated products, all made to comply with European demands for extended cat longevity.
This is precisely why one needs to look very carefully at the details about any oil you decide to use. Or,....talk to people who have built engines for a living for awhile.
FWIW, a well known boutique oil manufacturer did run a VOA on Porsche's 20w-50 oil and found less than 1000 ppm of ZDDP along with shear problems that rendered this product into a 30w rather quickly indicating low-quality base stocks.
#75
Older thread but thought I would mention something. Everyone is fully aware that Swepco 201 is "the" oil for your transmission and all of the benefits/magic it does for Porsche transmissions. An equally superior oil is made by Swepco for the engine too. That is Swepco 306 20w50. Not trying to start up a pros and cons on oils just providing info and something to consider. My 1976 911 (with 82sc 3.0) really loves the stuff - runs smoother and cooler.
