The silly little question thread ...
#391
Thanks.
I took some pictures of my 90 door cards and I was surprised to see that the 90 had a black box under the handle. the wires you showed seem to be for the tweeters. But being a 94 I would assume they had the built in crossover mine is a 93 and I don't recall any crossover under the door handle. I can post pics tomorrow of the 90 if you need them.
search part number 96464550300
#392
I might as well post the pictures I took.
These are from a 90 C4
#394
I have never seen a pic of the wire frame inside our shift boots, but will this one fit just the same? Have to get a boot for the new ****, but the past owner had just gotten a new boot, and I really don't want to cut into it.
p/n: 944-552-257-00-OEM
http://www.pelicanparts.com/cgi-bin/...Each%2520%2520
#396
Definitely silly question:
I have a brey-krause strut brace I'm looking to install. Is it as easy as undoing 2 nuts on each strut brace, sliding the strut brace on, and re-bolting the nuts? I shouldn't be afraid of having the car collapse on itself when I pull out the nuts that sit on top of the strut brace?
#398
That won't fit. Its a very simple wire that is shaped in a square to go in the console. Much like a coat hanger shaped in a square.
I'll take a picture when I get home, I took my boot appart to redo it. No way Porsche is getting $250 for a new one.
#399
Found my misplaced boot and see what you mean. Do you know a certain type wire that is malleable enough to just recreate the wire frame? It seems a bit thicker than the coat thin metal coat hangers I have lying around.
#401
I'd try a hardware store...or perhaps a fabric store?
#403
Another car forum suggested piano wire bent into the same shape as the boot frame, so I'l try that.
Wouldn't this harm the steering rack eventually?
My silly question: anyone know where I can get the brake master cylinder (circular) o-ring? I don't see it listed separately.
#404
Technical Guru
