Help with noise - squeak from steering wheel
I get an occasional squeak (high pitched) when slightly turning the steering wheel - if I quickly jiggle wheel back and forth a few degrees can get it too - sounds like something in the steering rack (close to the steering wheel rubbing) - is there anything I can easily access to lubricate?
Sounds like something in there just needs some lithium grease.
(I can get the sound even with car at a standstill)
Thanks!
Thanks!
Technical Guru
I never had sounds with the stock wheel, but Jason's solution is what I did on my momo wheel/hub to reduce the weezing noise at low speed turning.
This is the grease I went with, conductive and made for high friction areas.
Amazon.com: MG Chemicals Carbon Conductive Grease : 846-80G: Everything Else
Professor of Pending Projects
I ended up applying a small amount of lithium grease to a long cotton tipped swab and placed it around the metal ring that the horn contacts. Squeak gone and didn't have to remove steering wheel.
Thanks for the help !
