964 Forum 1989-1994
Engine cold and warm reaction
Old 11-28-2013, 06:24 PM
jadh
jadh's Avatar
Question Engine cold and warm reaction
hello,
I have noticed that engine reaction to acceleration is different depending if engine is cold or warm. Indeed, my engine is more lazy when hot.
Please watch the following videos before posting.
Here is video of engine reactions when cold : ie just after engine start.
--> I like this quick reaction of the engine when I kick the accelerator!
Here are the videos when engine is at service temperature.
From the engine bay
and
From the driver seat
--> you can see the revs falling down when I am close to idle and when I quick the accelerator. I do not like
My engine is a 1992 full stock and has 103 000km
QUESTIONS:
Do your 964 engine has the same LAZY mode when hot? I mean less reactiv when hot comparing with cold.
For Rennlisters with a stock 964 engine, could you post the videos of your engine reactions, specialy if hot engine reactions are more reactiv when comparing with mine?
Thanks for your help!
Abstract of the Answers
Points to check :
- KTS diagnostic. How to do : go to your Porsche specialist and ask for a KTS diagnostic
- Lazy O2 sensor. How to do : KTS diagnostic
- is the vacuum system ok? How to do : just start the engine to make sure a vacuum is there then the resonance valve should move the next time the ignition is switched on. The resonance valve is a small black actuator operated by a solenoid / vacuum. It is located on the lower inlet crossover but is not visible. You can hear it 'clack' and see the spindle move when stood looking at the engine. ------> OK
- Check Idle Stabilisation Valve. How to do : Once at hot idle just pull the electrical plug Idle should stay roughly correct then try opening the throttle like in the other videos. Any different?
- Check both the ISV and AFM to make sure they are clean. How to do : https://rennlist.com/forums/964-1989...low-meter.html and https://rennlist.com/forums/964-foru...-answered.html
- Have a vidéo of a unlazy stock engine. How to do : A (nice) Rennlister to make the vids
Old 11-29-2013, 09:55 AM
jlmartin94
jlmartin94's Avatar
hi jadh
hope 964 rennlisters will be more objective than french forumers ...
It seem that everybody think there is trouble with your engine but nobody want to put video of their own motor reactions ....
Old 11-29-2013, 11:09 AM
Vandit
Vandit's Avatar
Are you running the heater in the operating temperature vids?
Old 11-29-2013, 11:44 AM
jadh
jadh's Avatar
Hi jlmartin!
I am not surprised to meet you in Rennlist Forum. It's always a pleasure to read you!
Yes you are true, I want to enlarge the scope of forumers for a better sharing about engine reactions.
Let's see if we get more (open minded & constructive) feedback here.
I am sure we will!
Hi Forumers, I need your help!
Do your 964 stock engine got the same lazy reactions as mine when engine is warm?
The French feedbacks are fifty/fifty about it! And moreover, I need a video of a 964 stock engine with "best in class" reactivity.
So, If you think that your engine is "Best In Class", please put a video of its engine reaction at sevice temperature.
Thanks a lot for your help!
Old 11-29-2013, 11:46 AM
jadh
jadh's Avatar
No heater and no air-conditioning on during the videos
Old 11-29-2013, 12:19 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
What is the cylinder head temperature in the warm videos? You could have a lazy O2 sensor. Do you have access to a Bosch hammer or Doug's scantool?
Old 11-29-2013, 01:20 PM
jadh
jadh's Avatar
I don't have the KTS tool and this car doesn't have the Check engine light. And I didn't had the opportunity to go to my specialist up to now
I don't know about cylinder head temp, but lubrication oil temp indicator was roughly horizontal during the test.
Old 11-29-2013, 01:48 PM
jevvy964
jevvy964's Avatar
have you tried unplugging the ISV to take that out the equation?
that "chuff" noise sounds like the ISV to me?
Old 11-29-2013, 01:56 PM
boxsey911
boxsey911's Avatar
Originally Posted by jadh
QUESTIONS:
In answer to your question, no mine is not as lazy as that. Sorry I can't be of more help than that at the moment.
Old 11-29-2013, 04:24 PM
jadh
jadh's Avatar
Hello Jevvy, What are the words for ISV (Intake S? Valve)? and please what is the unplugging procedure?
Old 11-29-2013, 04:38 PM
jadh
jadh's Avatar
Thanks for this information!
It is very helpful to read that your car is less lazy!
For sure you can help very simply, if you agree and if your car has a stock engine a 20sec video (engine & driver seat) could help me in setting the target to achieve.
Old 11-29-2013, 04:58 PM
crg53
crg53's Avatar
ISV= Idle Stabilisation Valve, located on top of the intake.
Old 11-29-2013, 05:00 PM
LPMM
LPMM's Avatar
Other quick checks: vacuum leak, FPR
PS: Here is a Visual Guide to the 964 Engine.
Old 11-29-2013, 05:23 PM
jadh
jadh's Avatar
@Crg53 & LPMM : Thanks!
I will have a look to linked threads.
But the problem I have is the following: I don't know what is the "normal" stock engine reaction sound?? So, if I perform some test, I will not be able to tell if I am closer to the target.
Anyone to help me with vids on that point?
Old 11-29-2013, 05:30 PM
jevvy964
jevvy964's Avatar
Previous replies should have helped you with the ISV location. Once at hot idle just pull the electrical plug at the top of this pic:
I will try to get a 964 cold/hot video for you over the weekend.
Quick Reply: Engine cold and warm reaction
