964 Forum 1989-1994
Scan tool & interface for bleeding C4 ??
Old 08-18-2013, 04:54 AM
kos11-12
kos11-12's Avatar
Default Scan tool & interface for bleeding C4 ??
Hi guys ,
I am considering getting a scan tool (or software) & the interface,
I was wondering if you guys know where can I buy those, I would need to be able to bleed the PDAS system as it is for a C4 .
Old 08-18-2013, 05:22 AM
ghhally
ghhally's Avatar
http://http://www.bergvillfx.com/products.html
Tore is your man
Old 08-18-2013, 06:29 AM
Laker
Laker's Avatar
In case Tore's can't bleed the locks: (not sure?)
http://928-ecu-repair.com/handheld_intro_index_eng.html
Old 08-18-2013, 06:37 AM
alexjc4
alexjc4's Avatar
I understand that Tore's one doesn't support the c4 awd bleed sadly. The more expensive Dutch "hammer" copy does I think (lakers post)
But no matter you can bleed the awd by hand, streather explains how to do the bomb and solenoid then to do the slave cylinders; with the ignition on, activate the diff lock switch and then crack open the bleeders (obviously fluid comes out with some force) , close nipple, release diff lock and reactivate, and repeat 10-20times unit you get clear fluid.
Old 08-18-2013, 06:48 AM
ghhally
ghhally's Avatar
Sorry Kos, was to quick!
+1
Old 08-18-2013, 08:42 AM
kos11-12
kos11-12's Avatar
Great news, I thought I read that somewhere in this forum long time ago, but a recent search got me in to a threat where Adrian was saying you can't with out scan toll .
Old 08-18-2013, 08:58 AM
kos11-12
kos11-12's Avatar
Geert & Laker thanks for the info
I will call them to find out
Old 08-18-2013, 09:55 AM
ghhally
ghhally's Avatar
Done it last week on C4 track toy
Old 08-18-2013, 10:22 AM
kos11-12
kos11-12's Avatar
Need to get Adrian's book then
Old 08-18-2013, 03:29 PM
ghhally
ghhally's Avatar
All you need to know
https://rennlist.com/forums/964-foru...procedure.html
Old 08-18-2013, 03:30 PM
Lemass Automotive
Lemass Automotive's Avatar
bled mine manually, takes a bit of time and help from a mate but had no problems
Old 08-19-2013, 04:39 PM
kos11-12
kos11-12's Avatar
Thank Geert ,
being reading Ricardo's great thread about 20 times,
I think I try the poor man's method ,
Quick Reply: Scan tool & interface for bleeding C4 ??
