964 Forum 1989-1994
brake adjustment on a c2
Old 08-06-2013, 11:38 PM
cobias1
cobias1's Avatar
Default brake adjustment on a c2
I may have asked this before but not sure so gonna do it again. Is the proportioning valve only on c4's? I seem to have much more braking in the front of the car than the rear. I have a c2 and if there is a proportioning valve that I can adjust I would like to try that before investing in bigger pads or rotors or other types of dollaristic fixes. thanks in advance for any replies.
Dan
Old 08-06-2013, 11:46 PM
Vandit
Vandit's Avatar
What year is your C2? 4 or 2 piston rear brake calipers?
My car is a '91 C2 w/ the small 2-piston rear calipers. I found a set of 4-piston rears off of '92+ 964 and installed them. At the same time gutted my proportioning valve to maximize the rearward bias.
Directions on how to gut your proportioning valve
It's a free mod and reversible in case you don't like the additional rear bias.
The 2-piston calipers are actually more hydraulically efficient than the 4-piston calipers, so given identical cars, the car w/ the smaller rear calipers is going to have more reward bias than the 4-piston car.
And here's a whole bunch of further reading including technical specifications for all types of alternative brake setups.
http://www.964uk.com/Documents/Pano%...cle%202005.pdf
And here's a bunch of technical discussion regarding calculating brake force according to system parameters, pistons sizes, bias valves, and all sorts of factors.
https://rennlist.com/forums/964-foru...-needed-4.html
Quick Reply: brake adjustment on a c2
