964 Forum 1989-1994
Black Betty - Back in Black
Old 04-03-2013, 06:14 PM
  #46
Jevo
Jevo's Avatar
Surely someone has developed a 964 C4 short shift by now that doesn't need to dimple the undertray???
  #47
BLACK-BETTY
BLACK-BETTY's Avatar
Originally Posted by Paul284pt
Hi Frank,
Nice Monte-Carlo!! Isn't temptation wonderful?
It will look beautiful installed, a nice finishing touch
Cheers mate, you're a bad influence.
Originally Posted by deutschland-dobson
What's your thoughts for mounting the dash timer Frank?
Just bolt to dash or try to integrate it some how?
I'm thinking bolted to the right hand side of the glove box lid.
Originally Posted by freedman
http://www.type911shop.co.uk/shop/ar...6aid%3D5658%26
On a C4 you need to dimple or box in the bottom of the shift lever as shown above
I dont think its too difficult though, and its a cheap mod
Ahhhh turns out the RS one is the same as the C4 one.... or so Mathew at Type911 says... will post findings.
Roomer has it there's away to do it without the dimple tray...
Old 04-04-2013, 08:39 AM
  #48
BLACK-BETTY
Detailed pics and video to come.
Old 04-04-2013, 08:42 AM
  #49
davidwilson11
davidwilson11's Avatar
cannot beat a good bit of detailing, I try myself and do it but its no where near as good as the pro's are at it.
Old 04-04-2013, 09:03 AM
  #50
freedman
freedman's Avatar
Yes the lever is the same, the C4 doesnt use the additional fork that the C2 does, hence its s lightly cheaper than a C2 kit
Cant see there is a way to do it without modding the tray, but I'm intrigued to hear if there is
Old 04-04-2013, 04:38 PM
  #51
Paul284pt
Paul284pt's Avatar
Hi Frank,
You've helped me spend my money, it's the least I could do
I hope you haven't started drilling your glovebox yet, this is what I fixed mine with. I cut the heads off some bolts then super-glued them into the countersunk positions on the plate to look like they've bolted through.
Then fix 2 strips to the back of the mounting bracket before fixing in position on the glove-box. Each strip can carry 2.5kg's of weight (see packet) so you won't have any issues with it falling off (so long as you degrease the glove-box first). I haven't had any problems and we have some bumpy roads around here.
The good news is that if you ever need to remove the bracket you just need some strong fishing line and slip it behind the bracket, use it like a cheese wire and simply clean the area up
Regarding the short-shift, this is what I left Nick with my car and he said he'll sort it out. When I find out what how he plans to fit it I'll let you know, or you can ask him yourself if you're in a hurry although I know it will be different for C4
Cheers,
Paul
Old 04-04-2013, 04:54 PM
  #52
Jevo
Jevo's Avatar
Yes please do tell I'm all ears said the elephant!
Old 04-04-2013, 05:08 PM
  #53
peterC2S
peterC2S's Avatar
+1 on that. The only one I've seen that doesn't require modding is the RUF SS kit.
Old 04-05-2013, 05:12 AM
  #54
deutschland-dobson
deutschland-dobson's Avatar
Ive used these at work and they're great. They can hold quite a bit of weight
If I remember corectly a good strong twist of the part being supported will break the strips free, so a cheese wire may not be needed.
Chris
Old 04-05-2013, 05:17 AM
  #55
jack.pe
jack.pe's Avatar
Good to see you last night Frank.. BB was looking good and fairly menacing in those tunnels.. Engine looks awesome!
Old 04-09-2013, 03:50 PM
  #56
Zingari
Zingari's Avatar
Speaking of Rally Clocks, I couldn't help myslef but buy this twinset :
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=171013558398
£150 or offers (Try £130) The seller gets several sets in. The height of the backplate is 60mm so will fit the glovebox panel before the outward crease
I'll probably spray the plate/clips black to blend into teh dash but keep the clockcs silver. No more nails will be the way to go with 4 x 'false' screw heads.
Another (small) wallet buster session!
Old 04-09-2013, 04:11 PM
  #57
Rephlex
Rephlex's Avatar
Top bombing!
Old 04-09-2013, 04:52 PM
  #58
kos11-12
kos11-12's Avatar
Hi Frank ,
Found that a few months ago ...
http://www.classic-rally-timing.fr/, not as sexy as your clocks....
And this , http://www.rcscables.com/
Wonder if they have a proper quick shift that will work with our gearboxes ...and affordable ...
Enjoy your trip in the Alps !
Old 04-09-2013, 05:26 PM
  #59
alexjc4
alexjc4's Avatar
While they are lovely to look at there is something a bit anachronistic about analog rally clocks in a 1990 car, period correct would be a rally computer like this:
to a geek like me thats pretty cool looking, of course if you put that in your car you would be forced to do some time trial continuity type road rallies to try it out
Old 04-09-2013, 05:34 PM
  #60
Paul284pt
Paul284pt's Avatar
Very classy Brian
Paul
Quick Reply: Black Betty - Back in Black
