Rear Center Light Substitution Panel
#46
Since you are entertaining a custom solution, there are a fair amount of custom fabricators that you can contact. I've seen these guys at SEMA, their work is nice. http://www.racemeshgrilles.com/customfabs.htm
#47
#51
Oval holes not my cup of tea either. If it was a plain panel then it would look better. Can the fog lights not be included into the side cluster?
I really like the mesh/grill on the cars on P1 of theis thread. If you remove the reflector there is still a panel behind though isn't there so ho is that removed so the grill goes straight through to the engine?
#52
Edit: They are only available as pictured. I'm going to order one and fill the holes for the lights. I'll probably use some small led's mounted next to the license plate for reverse lights. The couldn't be any worse than the reverse lights in the reflector.
#53
After the recent interest he is now selling on ebay:
http://www.ebay.co.uk/itm/PORSCHE-96...item4d17328f8e
#54
#55
If this is your end goal, why not simply paint or vinyl wrap your center reflector instead? It seems to me that it would be a cheaper and better looking alternative alternative to that stick on piece. Even if you smooth out the holes and script, it will have a wavy look like it shows in the pictures and it will not sit flush with the tail lights.
#56
#58
#59
