964 Forum 1989-1994
Deleting the sunroof
Old 10-20-2014, 03:03 PM
  #46
freedman
freedman's Avatar
Originally Posted by jack.pe
Guys,
Have heard that welding in a panel, such as the Fenn Lane item often results in cracked welds later on as the rood twists under normal use and track work. Anyone know anyhting about this? I know replacing the whole rood is the best option but it is just too expensive.
Jack,
Thats another reason I thought Robs option was a decent compromise
The car looks like it still has a sunroof, so no issue with cracking or weld lines showing though and you still get the increased headroom (I could really do with it!) and 90% of the weight savings.
To make it lighter still us e a FG or carbon panel, but the same method?
Old 10-20-2014, 03:58 PM
  #47
jack.pe
jack.pe's Avatar
Originally Posted by freedman
Jack,
can't find the thread, what did Rob do? To be honest if I go for a delete I don't want it to still look like it has a sunroof..
Old 10-20-2014, 04:19 PM
  #48
Lemass Automotive
Lemass Automotive's Avatar
Rob took all the sunroof guts out and I just welded the original panel in leaving the grove between roof and sunroof panel. We were going to add black sealer so it looks like the felt but have just left it painted.
Old 10-20-2014, 04:39 PM
  #49
freedman
freedman's Avatar
Thread here Jack
https://rennlist.com/forums/964-foru...-almost-3.html
Old 10-20-2014, 05:17 PM
  #50
Captain Ahab Jr.
Captain Ahab Jr.'s Avatar
That's my plan but using a bond in a flush fitting carbon bond in panel
Plan to do it over winter so I'll post up each step as it happens
If I can achieve the quality I want and if enough people are interested in paying the price for an accurate fitting high quality panel then I'd be happy to get a small run made
Old 10-20-2014, 05:20 PM
  #51
jstyer
jstyer's Avatar
^^^^^^ I'm in the US... But would be very interested in this.
Old 10-20-2014, 05:26 PM
  #52
Rephlex
Rephlex's Avatar
Yes but I believe your roof was bonded and not welded?
Welded.
Old 10-20-2014, 06:29 PM
  #53
robt964
robt964's Avatar
Still haven't decided if I'd prefer it with a smooth black bead of sealer around it or just as is
Old 10-20-2014, 09:46 PM
  #54
cobalt
cobalt's Avatar
Received 1,929 Likes on 1,168 Posts
Guys,
I was worried about the same thing. My body man was confident if we spot welded it in place it would crack over time especially for track duty so we welded the entire panel both inside and out giving the panel double strength. He guarantees me it will never crack. It was many hours work but worth it. Only time will tell but if it cracks he will fix it for free.
Old 10-21-2014, 05:27 AM
  #55
freedman
freedman's Avatar
http://www.ebay.co.uk/itm/Porsche-91...item2596d562e3
Old 10-26-2014, 02:52 PM
  #56
Lemass Automotive
http://forums.pelicanparts.com/porsc...-skins-fs.html
Old 10-26-2014, 02:58 PM
  #57
Rephlex
Rephlex's Avatar
No lip all the way around - think the Fenn Lane panel is superior in this regard.
If you want a carbon roof panel, speak to Ken at Nine Excellence, he can supply and has such a roof on his '64.
Old 10-26-2014, 03:30 PM
  #58
Lemass Automotive
Does he have a roll cage?
Old 10-26-2014, 03:31 PM
  #59
Rephlex
Rephlex's Avatar
No he doesn't
Old 10-26-2014, 03:38 PM
  #60
Lemass Automotive
Ooh
Quick Reply: Deleting the sunroof
