rear wheel stud replacement
Curious, does anyone have any tricks on replacing the wheel studs or do I have to remove the hub, from the bearing, from the knuckle? Thanks. I did a search but wasn't 100% clear. If anyone have any tips please let me know, thanks
Clayton
Clayton
I believe there is a gap behind the hub/disc that you can pull the stud out from but you can only do one at a time and need to rotate the disc to align the stud you want to remove with the gap.
This is assuming you have standard length studs, there is room to put slightly longer studs(78mm springs to mind) but if you want to go any longer then you need to pull the hub.
HTH
HTH
