Trunk Lid Release
Trunk Lid Release
My trunk release arm (the lever close to the clutch pedal) is not working. I pull it but it doesn't open the trunk. What might be wrong with it? Is there a DIY for it?
Thank you.
Tim
Thank you.
Tim
I believe that 91+ had the emergency release cable. If you can get at the cable inside your car, put a vice grip on it and pull, then replace the cable. If not,there are many threads about this issue. If your car does not have the emergency cable, you should install some, front & rear.
