964 Forum 1989-1994
8ET50 Install & Photos
Old 11-23-2010, 06:43 AM
sml
sml's Avatar
Default 8ET50 Install & Photos
Just bolted on 8" ET50 wheels with 235/40 Kuhmo Ecsta XS KU36 tyres.
Car is at RS height -10mm.
Camber unknown (alignment is pending).
Clearance is about 1cm between the tyre and the guard. I can't squeeze my hand between the guard & tyre.
Shocks are about 450lbs.
Yet to test drive .. fingers crossed there is no rubbing.
Here are some pics which might help those deliberating with wheel offsets, width and tyre sizes.
Old 11-23-2010, 12:44 PM
Dwane
Dwane's Avatar
What did you put in the rear? 18x10 et 40
18x9.5 et 47 looks great on the rear.
Old 11-23-2010, 12:49 PM
SuperUser
SuperUser's Avatar
Nice!
Old 11-23-2010, 04:25 PM
sml
sml's Avatar
The rear wheels should arrive later today but I went for 10ET40. I have the car quite low, so I am expecting to crunch the fender.
It was nice of that guy to post photos of his 10ET40 Alleggerita wheels (side-on from a distance) .... but a few more close-ups would have been helpful
Old 11-25-2010, 08:27 AM
sml
sml's Avatar
Took the car for a drive this morning and the 235/40R18 8ET50 rubbed on the front corner at the joint between the panel and bumper.
I shaved down that corner joint with an angle grinder, then noticed that it rubs against the screw fixing that black plastic fender lining - only on the one left side. I then removed the screw as a temporary fix and it is almost ok, but the corner of the left tyre still rubs the black plastic lining when turning the wheel slightly to the right. The lining has some 'give' in it so I think it will be ok for a few days and will get the pros to sort it out next week.
In hindsight, I should have gone for 225/40. EDIT: read below ...
Old 12-06-2010, 04:58 AM
sml
sml's Avatar
Update .. height adjustment, wheel alignment, and fender lip rolling on the rear.
Incorrect .. 235/40 is perfect with the correct alignment.
Wheel alignment was carried out today and the caster was maxed out at 2 degrees. We could not close to the 4 degrees as per the porsche specs.
When the caster was adjusted by 0.5 degree, this shifted the front wheel about 2 to 3mm rearwards, and there are no problems with the tyre hitting that black inside fender panel.
Old 12-06-2010, 05:01 AM
sml
sml's Avatar
Photos ...
Height =120mm RIGHT and 115mm LEFT (outcome from mechanic adjustments!? - might need to review later!?) ... this is RS-5mm and RS-10mm.
Camber = -2 degrees
Toe = 1/8 out
Old 12-06-2010, 05:02 AM
sml
sml's Avatar
Hope this helps someone selecting their wheels in years to come.
Old 10-27-2011, 09:21 PM
GoKart
GoKart's Avatar
Nice car, and nice wheels!
I also like the "Carrera" script decal --- where did you get that?
Old 10-27-2011, 09:34 PM
sml
sml's Avatar
Please read your previous thread ...
https://rennlist.com/forums/964-foru...ra-decals.html
And dont forget there are 2 fonts ... old school and a more modern font. I chose the more modern font which is a close match to the Carrera writing on the rear spoiler (rather than the old school font from the '70s.)
Old 10-27-2011, 11:30 PM
f3nr15
f3nr15's Avatar
Hey sml,
Is your old gal up for grabs?
Thought I noticed it on carsales.com.au recently.
Upgrading?
Old 10-28-2011, 02:24 AM
sml
sml's Avatar
hi f3nr15,
yep .... but unfortunately it's not an upgrade ... the new house build has taken a priority so i think we'll get by with one car for a while.
disappointing as it's the only car that gets more enjoyable the longer that you own it.
Old 10-28-2011, 09:24 AM
CWay27
CWay27's Avatar
I started reading this thread and immediately saw that you didn't have enough camber and too much caster. How did it work with the rears??
Old 10-28-2011, 05:43 PM
sml
sml's Avatar
yes, fortunately it was about a year ago, but there was a few days of worry until it clicked that the castor was the problem on one side. i was amazed how much the castor adjustment can move the front wheel.
rears are going good, except the tire wear on the inside edge due to the max neg camber. there is still clearance to reduce the neg camber and bring the tyre edge closer to within 1mm from the guard edge
https://rennlist.com/forums/964-foru...40-photos.html
Old 08-01-2012, 10:07 PM
MrNvgtr
MrNvgtr's Avatar
Thank God there's potentially hope after some final camber/caster adjustment.
I've read your thread in the past, but for some reason my memory of what you went through didn't click until now that I'm experiencing a similar issue. I just drove my car home to drive for a few days to let the springs settle before taking it back for it's final height adjustment, alignment, spacing (rears), and corner balance. My front wheels and tires are almost the same spec (8.15" wide and et50) and I'm experiencing the EXACT same thing you wrote about in your original post. Unfortunately I have another .15" width on you, and it looks like it's on the outside (bad).
What's been bringing me down the past few days is the realization that I won't be able to go quite as low as I envisioned. The height is roughly set somewhere around RS-5 to RS-10mm. I'm at max low in the front right now with a slight rub at about 10 - 15 deg turning, but plenty of room in the rear. My rears are a little more conservative (9.75" wide and et50). Looks like the rears will actually need about 8 mm of spacer to bring them out where I want them.
Frustrating to say the least. I'm pondering a few options, but I'd rather just keep things where there at now and somehow massage the fenders where needed. The other alternatives I can think of are an outside rim half swap-out or possibly smaller width tires (225 or even 215), but that's sort of an unknown if that latter option would work.
Maybe it doesn't look so bad from an outside perspective. I just had a certain look in my mind and after lots of money its looking like I'm not going to achieve it.
Looking down from the front edge of drivers front fender
Looking down over top edge of drivers front fender
Looking forward from behind drivers front fender
Profile shot of drivers front wheel
Not too shabby from a distance. Just wish I could be about 3/4" lower. If only I could call upon Naki San to make it work and had endless amounts of money.
Quick Reply: 8ET50 Install & Photos
