964 Forum 1989-1994
smell of burnt rubber when clutch slipping ?
Old 08-30-2010, 03:57 PM
964enthus
964enthus's Avatar
Default smell of burnt rubber when clutch slipping ?
Hi !
when i get the clutch slip ,for example to get on car ramps ,there is a distinctive smell of burnt rubber
No problem whatsoever with the clutch (clutch changed a few years ago ,maybe 15 000 miles now- and just done a 1000 mile trip,including long start and stop periods )
I have never noticed such a smell on any of my other cars
Is this normal?
any idea what is causing that smell
peter
Old 08-30-2010, 04:11 PM
R6XTERRA
R6XTERRA's Avatar
could it be a an RMS failure, possibly leaking oil on the clutch?
Old 08-30-2010, 05:00 PM
964enthus
964enthus's Avatar
thanks for your response
were that to be an RMS failure ,i suppose it would rapidly destroy the clutch
Clutch is very strong ,no smell in normal driving conditions ,only when slipping for a bit like to get onto car ramps
Last ,it is typically a burnt rubber smell ,not a burnt oil smell(like when a drop of oil falls onto the heat exchanger !!)
why rubber ?
Peter
Old 08-30-2010, 05:32 PM
crg53
crg53's Avatar
What you are describing sounds normal to me. Taking off up a steep hill, I sometimes get a viff of the clutch, no problem just don't overdo it.
Old 08-30-2010, 06:33 PM
Earlydays
Earlydays's Avatar
It's a normal "slipping clutch" smell.....
Old 08-30-2010, 08:34 PM
tbennett017
tbennett017's Avatar
That's what $$ smells like when you burn it. I get that now and then with mine... I think it's exacerbated by the airflow around the engine. Its no big deal.
Old 08-30-2010, 11:38 PM
altarchsa
altarchsa's Avatar
Sorry to hijack your thread, but I'm curious about the RMS failure and destroyed clutch comment. I did a complete rebuild about 8 months ago and the car runs great, but I developed a serious oil leak about 2 months back. It drips from the bottom.of the bell housing onto the crossover and generates a lot of smoke and smell.
I have not been able to locate the leak exactly. I had hoped it was the o.p. sender, but I replaced that and no improvement. The cover gasket and o-rings are new, so I don't think that's it. I am worried that it's the RMS because I can tell there's oil getting into the starter. I thought maybe I damaged the RMS, or it somehow became displaced.However, there's no deterioration of the clutch function. Can it be the RMS and not get the clutch wet?
Any suggestions?
Old 08-31-2010, 12:07 AM
darth
darth's Avatar
The only rubber near the clutch is the center of the flywheel. The clutch should not slip unless its' worn, oil is on the surface or the center rubber is detaching from the flywheel and spinning, hence the rubber smell. Or there's so much power back there that you're smoking the tires and don't know it
Old 08-31-2010, 04:01 AM
964enthus
964enthus's Avatar
Interesting comments received !!
Difficult to reconcile some of the views though ,
Some of you say it is quite normal and others say things like :
"the center rubber is detaching from the flywheel and spinning",
maybe if we could understand exactly what happens when we let the clutch slip ,we would be able to determine if the smell is" normal" or not
Ps : never seen a rubber centre on a clutch on my other cars .Any Idea why the P engineers designed it that way ?
Peter
Old 08-31-2010, 06:00 AM
Amroth
Amroth's Avatar
It's normal to smell something when the clutch slips, I don't think you should worry unless your clutch slips during normal driving conditions....
Old 08-31-2010, 04:27 PM
R6XTERRA
R6XTERRA's Avatar
Any suggestions?
My RMS was diagnosed 3 years ago to be leaking...very little. Mine was leaking at the bell housing as well. I was able to drive 3 years with no problems. I just did the RMS and clutch on my car since the clutch was on its way out.
Jeff
Old 08-31-2010, 08:13 PM
altarchsa
altarchsa's Avatar
Jeff
Thanks! I guess that's good news and bad news. Hopefully I won't damage the clutch disk, but it means I'll have to get in there and do the RMS - engine out....again.
Old 09-01-2010, 02:05 AM
Jimjacqmx5
Jimjacqmx5's Avatar
I get this wiff if you slip the clutch a bit. Yes, you aren't really doing anything that you don't do in another car. My theory is that you just get it sucked up in to the cabin through the heating ventilation etc and that is why it hits you so hard. Perhaps in other cars you dont even notice it as the 'smell' is dissipated outside the car. I have had this happen in very minor slips when manouvering up a steep driveway etc. I just pulled my engine out for other reasons recently and the clutch is perfect so i wouldn't worry.
Old 09-01-2010, 03:46 PM
964enthus
964enthus's Avatar
many thanks to you all for your -reassuring !- comments
Old 09-01-2010, 05:18 PM
R6XTERRA
R6XTERRA's Avatar
I put a 996TT clutch in my car....only rubber burning now is the tires....lol
Ps. When I had my old clutch in both my 89 c4 and my 91 cab, I sometimes got a burnt rubber smell as well, this was under hard acceleration shifting through the gears or launching a little harder than i should have. I never ever randomly smelt a burnt rubber smell under regular driving. I would attribute it to slipping the clutch.
Jeff
Quick Reply: smell of burnt rubber when clutch slipping ?
