964 Forum 1989-1994
Hall sensor Connector Plug Severed
Old 12-03-2009, 09:31 PM
Ryan360
Ryan360's Avatar
Default Hall sensor Connector Plug Severed
Help! I unwrapped the electrical tape around the hall sensor plug and found ground wire severed and missing pin (see pics). It was like this when I bought the car. I think the previous owner damaged it when replacing belt. Now DME logging 34 (hall sensor defective).
I am hoping to replace just the plug w/pins by splicing it to existing wires. Does anyone know where I can find a hall sensor connector plug replacement- new or used? Part number is helpful if available. Thanks.
Old 12-03-2009, 10:08 PM
Geoffrey
Geoffrey's Avatar
I have the connector and terminals in stock for when I do MoTeC wiring harnesses. Call me tomorrow and I can send one out.
Old 12-05-2009, 05:17 PM
Ryan360
Ryan360's Avatar
Geoffrey,
Thanks, this is much appreciated. Pls check your PM for my info.
Old 12-22-2009, 12:44 AM
Ryan360
Ryan360's Avatar
I finally were able to replace broken plug and reconnect ground terminal thanks to Geoffrey's kit from MoTec. I'm posting some pics for anyone interested.
http://s911.photobucket.com/albums/a...view=slideshow
Old 08-07-2012, 04:41 PM
Jebarco Hairston
Jebarco Hairston's Avatar
Can someone send me a part number to this hall sensor connector on the dis? Mine is broken...
Old 01-15-2014, 06:58 PM
Cedric 18
Cedric 18's Avatar
Geoffrey, can I get the same connector-terminal from you? I have the same problem.
thanks, cedric
Old 01-15-2014, 08:05 PM
Alex Sol
Alex Sol's Avatar
how is it running without the hall sensor properly connected? mine has some issues which i too need to fix,
my C2 feels like it's running on 3 cylinders and i'm getting 4-5 kms per litre of premium fuel.... i may have a engine harness issue... definitely electrical and not mechanical...
oddly, i did not get error code when running hammer scan...
Old 01-16-2014, 11:17 AM
Cedric 18
Cedric 18's Avatar
The car was running fine but I installed a chip from Steve Wong and nothing changed; he mentioned that my car is not running to it's full potential already. Since it's winter here and I can't drive the car, I am checking all the wiring harness to find any damaged wires, and I found this when taking the tape off (actually broke when taking the tape off). Code 23, closed loop system limit.
Old 05-29-2017, 01:11 AM
Hotrodaxel1976
Hotrodaxel1976's Avatar
I can't even find my hall sensor to replace it, my car is not running properly at all, blue smoke out right tail pipe on cold starts, flashing cel, code p0343
Old 05-30-2017, 02:21 PM
jimq
Burgled
jimq's Avatar
I have gotten that hall sensor code since scan tool first came out 12 + years ago at least. I have checked connector numerous times. Car runs great so not so sure it is reading right.
Old 05-30-2017, 02:50 PM
Hotrodaxel1976
My Car runs horrible Trying to get it figured out now
Old 05-30-2017, 03:03 PM
Ken D
Ken D's Avatar
Hi hotrodaxel - I bet you meant to post this in the 996 forum? This is the 964 forum for the 89-94 air-cooled cars.
Old 05-30-2017, 03:08 PM
Hotrodaxel1976
No , I was reading everything and came across this, simply stated that I couldn't even find my hall sensor, that's all
Old 05-30-2017, 03:24 PM
Ken D
Ken D's Avatar
The hall sensor location in the 996 is completely different from the 964; a 964 owner wouldn't know where it is either. Someone from the 996 forum could assist.
But this thread might help? Looks like you need to get under the car to locate it. https://www.6speedonline.com/forums/...placement.html
Quick Reply: Hall sensor Connector Plug Severed
