964 Forum 1989-1994
964 Cup 1's...Made in Italy?
Old 09-24-2009, 07:04 PM
christallon
christallon's Avatar
Default 964 Cup 1's...Made in Italy?
I checked through the search first. Are the factory Cup 1's from the 965 made in Italy. The P-car part number is there, but I was not aware the wheels were made in Italy. Just looking for confirmation.
Thanks all,
Chris
Old 09-24-2009, 07:51 PM
Porsche917K
Porsche917K's Avatar
I just checked a factory set I have and they don't say made in Italy FWIW.
breale01
breale01's Avatar
I believe that to be correct. Mille Miglia as I understand. Mine are replicas and they are marked Made in Italy.
Old 09-24-2009, 09:20 PM
christallon
Yes,
I think the set I am looking at on craigslist are actually replicas. The seller states that the 965 porsche numbers are stamped on the back. I just looked at photo's of the front face of all wheels he emailed me and they do not have the numbers 7 and 9 next to the valve stems, so me thinky these are Mille Millie replicas.
Thanks guys.......
Old 09-24-2009, 10:17 PM
Porsche917K
You might consider them anyways. The Mille Miglias actually have a much better offset than stock cup 1's IMO.
Old 09-24-2009, 11:19 PM
christallon
They are ET 55's, the same as the turbo Cup 1's. I already have an oem set on the car, but thought a second set might be good to have, as long as they are oem. At $750 for a set of replica's, I'll have to pass.
Old 09-25-2009, 12:34 AM
pu911rsr
pu911rsr's Avatar
Chris,
The factory Cups 1's are Italian, the set I have in garage are stamped made in Italy on back. The factory wheels also have the width and offset on each side of valve stem. The easiest way to tell if they are aftermarket is to look at lug holes, the after market wheels will have a slight flat area on hub side of hole.
Phil
Old 09-25-2009, 06:14 AM
meek
meek's Avatar
^^ Yup, factory originals are Italian made and stamped as such. Did Mille Miglia make the originals as well as the replicas?
Henrik964
Henrik964's Avatar
Which ET have the MilleMiglia front and back?
Old 09-25-2009, 06:38 AM
ThomasC2
ThomasC2's Avatar
47 and 52
Old 09-25-2009, 11:17 AM
cobalt
cobalt's Avatar
Received 1,935 Likes on 1,170 Posts
There are 2 manufacturers for the Cup 1's. One is made in Italy not sure about the other. Part number is identical but one ends in a .00 the other in a .01. They look identical from the front but different from the rear.
Old 09-25-2009, 01:08 PM
christallon
According to the seller, his set has these numbers on the back and also say "Made in Italy"
2 Front= 17x7= ET55=965.362.124.00
2 Rear = 17x9=Et55=965.362.128.00
He sent me pics of the wheels and aside from them having been polished at some point, they look like Cup 1's, other than the fact that there are no numbers stamped on either side of the valve stem. Did all the OEM Cup 1's come with numbers on either side? Did the Mille M. wheels come with Porsche part numbers stamped on them?
Old 09-25-2009, 01:22 PM
cobalt
cobalt's Avatar
The numbers are correct and should be raised cast numbers on the back of the rib. The numbers on either side of the stem should be raised also. It is possible they removed the numbers while polishing. BTW the speedlines are made in Italy, I don't know if speedline made the cup I's or if it was BBS.
I have seen some cases (not on the cup I's) where the same wheel by same manufacturer was supplied with and without the ET and width cast on either side of the valve.
Old 09-25-2009, 02:38 PM
PAOLOP
PAOLOP's Avatar
The OEM are Speedline
Old 09-25-2009, 03:45 PM
cobalt
cobalt's Avatar
So made in Italy would be correct. I believe the .01 version of the 7 & 8" cup I's were made by BBS.
Quick Reply: 964 Cup 1's...Made in Italy?
