964 Forum 1989-1994
993 Engine Mounts in a 964
Old 05-29-2009, 06:32 AM
  #46
Scamper
Scamper's Avatar
i will find out later...in the office at the minute
Old 05-29-2009, 10:10 AM
  #47
Scamper
Scamper's Avatar
993 mounts are 993.375.049.05
Old 05-29-2009, 06:21 PM
  #48
mrmoots
mrmoots's Avatar
Thats great, thanks very much.
Old 05-29-2009, 09:34 PM
  #49
tgage
tgage's Avatar
Default ebay engine mounts // 993
I received the ebay version of the engine mounts today and installed them. They are absolutely not OEM as the ad seems to imply. The original mounts have a left and right side, apparently to compensate for differences in motion from engine torque, however, the replacement ones are identical. I think you get what you pay for, however, they appear to be functional and the threads have anti-slip coating on them. I'd go with OEM.
One pleasant but unexpected aspect of the 993 mounts is the much longer thread will alow a lower partial engine drop in the future for doing valve adjustments without having to fully take the supporting bolt off.
I already had the car on jackstands and so supported the engine with my jack and a "highly fabricated support block".
The mount is secured below by a 19 mm bolt for which you will need a long socket wrench (for the reinstall) and then removed the two retaining bolts on the top (13mm). The replacment goes right in and a new bolt (not included) is used below. Note that the engine mount has a square portion at its base that fits into the upper side of the engine mount. I did not measure the 13 mm bolts, but I believe they were M8 1.25 45 mm partial thread.
Once tight, I proceeded to the drivers side and replaced in a similar manner.
Since the old engine mounts leave the car hanging a bit lower, the engine will now have to be jacked up a tad to bring the engine up to the same level as the new engine mount base.
I then went below the car and tightened the 19 mm bolts the remaining way. I still need to check the torque setting for the bolts.
tom
Old 05-30-2009, 09:33 AM
  #50
yellowducman
yellowducman's Avatar
tom
The way I understand it is that the factory 993 mounts do not have a left or a right and are the same. Only the 964 mounts are different.
Old 05-30-2009, 11:54 AM
  #51
crg53
crg53's Avatar
I will be doing the same job this coming week, does anyboby know the torque spec's for the nuts.
Old 05-30-2009, 12:30 PM
  #52
dfinnegan
dfinnegan's Avatar
Engine Mounts
Lower Nuts: 85 Nm (63 ft-lbs)
Uppper Nuts: 25 Nm (34 ft-lbs)
Old 08-17-2009, 01:13 PM
  #53
HardTarget
HardTarget's Avatar
Bringing this back up, as the lower nuts on my OE mounts are 18mm, not 19mm as described in post #49. So just make sure you have both deep socket sizes...
Old 07-04-2010, 02:13 AM
  #54
oldskews4
oldskews4's Avatar
tgage,
Any reviews of the ebay mounts now that you've had them for a while. Are they holding up still?
Old 04-12-2015, 07:49 PM
  #55
Streetdaddy
Streetdaddy's Avatar
Shot?
Old 04-12-2015, 07:50 PM
  #56
Streetdaddy
This is my daily driver, thinking of the 993 version. What improvements should i expect?
Old 04-12-2015, 09:47 PM
  #57
JasonAndreas
Technical Guru
JasonAndreas's Avatar
What people are selling as OEM 993 engine mounts are not 993 engine mounts. 993 engine mounts are just like 964 engine mounts, they are hydraulic while these aftermarket versions use rubber. The difference between actual OE C2 and C4 engine mounts is the casing material. One is aluminum while the other is steel.
Old 04-13-2015, 09:08 AM
  #58
BHCfarkas
BHCfarkas's Avatar
I would much prefer a rubber mount than a problematic and often-failing hydraulic mount.
Old 04-13-2015, 09:27 AM
  #59
ThomasC2
ThomasC2's Avatar
Buy the Euro RS mounts! Works just fine for a daily driver as for a track car.
Old 04-13-2015, 09:36 AM
  #60
911Jetta
911Jetta's Avatar
You'll like this upgrade! But don't mess around with anything cheap, buy Porsche RS or Wevo motor mounts and be done with it.
My story:
Wevo m.m. installed - impressions
https://rennlist.com/forums/964-foru...ferrerid=19642
Quick Reply: 993 Engine Mounts in a 964
