964 Forum 1989-1994
'964 Top End and Clutch Rebuild
Old 05-18-2009, 11:28 AM
reinhart993
reinhart993's Avatar
Question '964 Top End and Clutch Rebuild
Now have 150k enjoyable miles - including some excellent track time - on my '964 and got to the point where I need a new clutch and top-end rebuild.
Does anyone have recent price information on a top-end rebuild? Recent price information on all-up costs for having a Porsche replacement engine put in? Pros and Cons? Have searched this forum but not found the answers yet.
Am currently near Princeton NJ - are there any shops in the area with a good track record? Have one vote for Holbert Motor Cars in Warrington, PA.
Thank you for any advice on this
Peter Reinhart
'964 - mostly stock, except brakes and wheels/tires
Old 05-18-2009, 02:46 PM
chas911
chas911's Avatar
Peter, try Bodymotion in Ocean, NJ. They are the engine builder for TRG and Marcus Motorsports. Mike Bavaro is a good guy.
Charlie
Old 05-18-2009, 02:51 PM
groovzilla
groovzilla's Avatar
Received 4,417 Likes on 2,692 Posts
$7000-$9000
Old 05-18-2009, 03:00 PM
geordie
geordie's Avatar
if you want to pay much less than the above quoted figure & can hack a 5 hour trip up to plaistow, new hampshire, many board members have praised exotech for their work
Old 05-18-2009, 03:01 PM
wellcraft290
wellcraft290's Avatar
I got qouted in NJ 4-5k for a top end job with new pistons and cylinders.
Old 05-18-2009, 05:18 PM
Streetfighter
Streetfighter's Avatar
Just curious, but how do you know it needs a top end?
Old 05-18-2009, 09:40 PM
reinhart993
Well - leaking a lot of oil now, 150k with quite a few track miles on odometer, and certainly needs a new clutch. Want to drive this 964 for another 20 years, so I figured a rebuild is in order.
Old 05-18-2009, 09:43 PM
groovzilla
groovzilla's Avatar
when i approached my shop and asked about top end and it was $6000 ($90hr)plus another $500 for machining the case for a gasket seal...this would include new rings and engine pad.
the clutch would be another $800 for parts plus labor and also extra for the flywheel machining or swap.
so here in seattle, its approx. $6500 for just the top end and add at least $1200 for the clutch.
Old 05-18-2009, 09:45 PM
reinhart993
Thank you al for comments. Found out a few more things by calling around today.
Porsche rebuilt engine has to be ordered from Germany - quoted cost $21,089
Top end rebuild from Princeton - approx. $10k -12k all in.
Top end rebuild from Holbert Motors - approx. $5k-$6k plus parts. Did not want to hazard a guess on cost of parts.
Seems the options range from approx. $10k to $21k + labor to install...
Cheers,
Peter Reinhart
Old 05-18-2009, 09:59 PM
JasonF
JasonF's Avatar
Peter,
Call Bill Boys at Possum Hollow Motorsports in Phoenixville, PA. He did an excellent job with my 993's top end/RS clutch and lightweight flywheel work.
My engine pulls very strongly and I don't burn through a drop of oil between 5k oil changes. It's an hour from Princeton and well worth the trip.
While you're at it, call Steve Weiner at Rennsport Systems to get better-than-oem valve guides and all the other bits and pieces that should be replaced "while you're in there."
Old 05-18-2009, 11:13 PM
wellcraft290
10-12k for just a top end? Protosport told me like 4-5k for rebuild for rings, pistons and cylinders and powertech in NJ told me 10-12 k for total rebuild. Seems high for 10k for just top end.
Old 05-18-2009, 11:25 PM
Colin 90 C2
Colin 90 C2's Avatar
reinhart993, i sent you a PM
Old 05-19-2009, 02:19 PM
reinhart993
Just called Protosport - I like these guys already. They will call me back tomorrow - out playing on the track today...
Peter Reinhart
(maybe a little less stock after the rebuild...)
Old 05-19-2009, 02:53 PM
BlueHeeler
BlueHeeler's Avatar
Peter Reinhart
Please post the quote.
$4-5k seems low to me.
Old 05-20-2009, 12:17 AM
wellcraft290
well was looking at a porsche that had a 25% leak down and for them for new pistons cylinders and rings was like 5k. I know they do a tiurbo kit and rebuild teh top end and shave down the cylinder for like 10k..
Quick Reply: '964 Top End and Clutch Rebuild
