Fire Extinguisher Install - Not too exciting but lots of pics
Wanted to share a fairly easy fire extinguisher install with my fellow listers:
Seats: Recaro Pole Position SPG (manual of course)
Extinguisher: OMP - went for a fairly large 2kg powder OMP Extinguisher
Mount: BK- FEM15 Porsche Shop UK or Stable Energies
I wanted a larger fire extinguisher than the teeny weenie little one in the GT3 so I went for a fairly large one - just in case! I was also thinking a lot about the install (roll bar mount? passenger side floor mount?) and decided that I did not want to risk a 2kg extinguisher coming lose in the car anywhere close to my head. I was also sensitive about being able to reach the extinguisher while still strapped into the harness. This led me to the seat front install.
BK - manual seat mount. It comes with 4 tapped holes and 4 screws (I only used 2):
OMP Powder Extinguisher with Mount (Halon not available in Europe):
Fire Extinguisher Mount by itself
Mount attached to the BK bar (mounting points on the extinguisher mount slide)
Mount attached to the BK bar with the extinguisher
The BK mount sandwiched in between the seat sliders and the Recaro side mounts (same as for the sub belt mount bar).
It clears the seat slide bar nicely (you are still able to pull it up to move the seat)
with extinguisher installed
Before:
Finished Product in the car. No problems moving the seat as the slide bar can be lifted to release the slide mechanism and the extinguisher slides with the seat. Legs don't touch the extinguisher:
Not affiliated with any of the vendors or stores (blah blah blah) - just like to products
Before:
That is a nice set up. My Region's tech form states that the driver has to be able to reach the extinguisher? It does not say anything about if this has to work when you are belted or harnessed? I had that mount from BK and the quick release= pretty nice but expensive. I hope you never have to use it! See my solution below:
The FE is something you hope you never have to use, however it's good to have one should someone ever be in trouble.
DE regulations are actually fairly easy here in Europe. In comparison to the US, I am not aware of any fire extinguisher or pre-tech inspection requirement. We don't have run groups and even give passenger rides!
Oracle, I have a much easier time with my two release buttons than reaching over into the passenger foot well? If I was racing or had really high DE ambitions and the cost associated with it, I would go for the "system". If I thought there was more risk of dying while driving at a DE versus the highway I would not do it?
2kg, 944, extinguisher, extingusher, fire, install, installation, instlation, instructions, mount, omp, porsche, recaro, slider, strap, system
