964 Forum 1989-1994
Motec kit - a fair price???
Old 12-10-2007, 05:45 PM
Jyrki
2nd Gear
Jyrki's Avatar
Default Motec kit - a fair price???
Unfortunately I need to sell my 964. I had gathered all the needed stuff to do a Motec conversion, so this needs to go too. What would you think I should/could ask for a complete kit?
- new MoTeC M600 ECU (the good ecu)
- programming cable USB
- new MoTeC to 964 Loom, made by a Motec-freelancer who works for WRC factory teams
- new set of matched Bosch 380cc injectors
- all new Auxilliary Sensors
- basic maps to get it started, but needs to be mapped on dyno
Jyrki
Old 12-10-2007, 06:44 PM
demonfish
demonfish's Avatar
you should ask for £500 and I will send it to you
Old 12-10-2007, 06:54 PM
madmoog
madmoog's Avatar
Demonfish, I was tempted to make a similar response as I'd like it too
Jyrki, Seriously though, check out the post from Colin (9m) about halfway down the page to get an idea https://rennlist.com/forums/showthre...apacity&page=3 , then divide by ten and offer it to me
Old 12-10-2007, 11:16 PM
Geoffrey
Geoffrey's Avatar
What options are enabled on the ECU? Specifically what sensors are included? What is the extent of the wire harness?
Old 12-11-2007, 12:03 AM
Ag02M5
Ag02M5's Avatar
Any of that gear good for a 964 turbo? EFI is a LONG term goal.
Old 12-11-2007, 02:28 AM
Jyrki
2nd Gear
Jyrki's Avatar
Geoffrey,
No options in this ECU, yet. Of course a wide-band lambda and data-logging would be nice. You can order these anytime you like (prices in AU$):
26101 M600 LOGGING 512Kb $ 178.86
26102 M600 SINGLE WIDEBAND LAMBDA $ 338.84
26103 M600 DUAL WIDEBAND LAMBDA $ 881.89
26105 M600 ADVANCED FUNCTIONS $ 535.19
26110 M600 ENABLE CODE $ 1,087.00
26112 M600 DRIVE BY WIRE $ 543.05
26116 M600 VARIABLE CAMSHAFT CONTROL $ 471.24
26117 M600 OVERRUN BOOST $ 275.00
Sensors included are TPS, Air Temp, and MAP.
The wire harness replaces the Motronic with Motec (bolt-on, reversible). There are also a shift-light and launch control options. The AFM-wires in engine compartment will be used for the new sensors. The harness is documented.
Ag02M5,
on a 965 you could use the Motec M600, but this harness wouldn't fit and the injectors are only good for ~450hp max.
I am aware of the price of the M600 unit (50% more than M48), just trying to find out what a complete kit goes for. The Ninemeister kit seems to include installation and mapping. The installation is very simple, but with my kit you'd need to find a dyno and someone capable of mapping the engine. My unit has 911 3.6 engine maps in it, but the maps are NOT optimised for 964.
Jyrki
Old 12-11-2007, 09:25 AM
Geoffrey
Geoffrey's Avatar
At 3.8bar of fuel pressure, the injectors are good for supporting a 400hp engine +/- a little.
In the US, the parts that you have would be roughly $4600 new.
The ECU would be great for a turbo EFI conversion. You'd want to upgrade to the dual lambda and 512k of logging although it does come enabled for 8 hours so you can utilize it to dyno tune the engine. The ECU allows for 4 different programs by simply turning a switch, and has enough input and outputs to do more than you'd want with for a TT Porsche application.
Quick Reply: Motec kit - a fair price???
