964 Forum 1989-1994
Scantool Diagnostic Interface Results Thread
Old 10-17-2006, 05:58 PM
Smokin
Smokin's Avatar
Default Scantool Diagnostic Interface Results Thread
It was suggested that we start a thread on the results obtained from the Diagnostic Interface. So... Here we go.
These test were performed with the engine at operating temperature.
At idle...
At 1000 RPM...
At 2000 RPM...
At 3000 RPM...
At 4000 RPM...
It will be interesting to see other's results. The one thing I have noticed on my results is that the ignition advance on my car seems to be higher than others.
So... Post your results! Let's see what we can find out!
Old 10-17-2006, 08:44 PM
gfunk
gfunk's Avatar
Rick,
I presume those tests were taken with no load? i.e. car was stationary?
Greg
Old 10-17-2006, 08:57 PM
Smokin
Smokin's Avatar
Originally Posted by gfunk
Rick,
Greg
Correct! No load... It was idling in the garage.
Old 10-17-2006, 09:36 PM
jimq
Burgled
jimq's Avatar
I have noticed everybody has a cylinder head temp of 244. Wonder if this is a glitch in the program or a top limit of written in the code.
Old 10-17-2006, 10:01 PM
Smokin
Smokin's Avatar
Jim... My cylinder head temp gauge isn't exact but it shows right in that range during the tests...
Old 10-17-2006, 11:15 PM
Red rooster
Red rooster's Avatar
Jim,
Its a top limit.
Geoff
Old 10-18-2006, 12:07 AM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Old 10-18-2006, 12:16 AM
Smokin
Smokin's Avatar
Originally Posted by Red rooster
Jim,
Its a top limit.
Geoff
Is it limited by the DME or the software?
Old 10-18-2006, 12:38 AM
911URGE
911URGE's Avatar
Here are mine. I was not as accurate on the RPM's. Ill try to post more accurate values this weekend.
Old 10-19-2006, 11:00 PM
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Cool
Here are mine...
First error code I notice when doing the first reading for the Motronic option was:
I proceeded to clear the code and I never saw it again during the tests.
No error codes for ABS nor for AirBag.
For Climate Control the 45-Inside sensor blower motor kept coming back
and the 44
Car with ignition on but not running:
Idle - Cold
Let me do another post to avoid reaching the limits in photos per post
Old 10-19-2006, 11:03 PM
Wachuko
Wachuko's Avatar
Cool
More:
Idle Warm
and the last one:
I was not able to perform the Adaptation it failed saying that the car was either not at operating temperature or Idle was Off... I know it was at operating temperature... but not sure how to change the idle setting it said was off...
Old 10-20-2006, 12:44 AM
Smokin
Smokin's Avatar
Jaime... Your last screen shot shows the WOT switch open and the idle switch closed... Were you revving the engine to wide open throttle at that time? If not... That's your culprit in reference to adaptation.
Old 10-20-2006, 12:46 AM
Wachuko
Wachuko's Avatar
Question
I left it at idle when doing the Adaptation... do I need to floor it while doing the adaptation???
Old 10-20-2006, 01:08 AM
Smokin
Smokin's Avatar
What I meant was that your last screen shot in the series... "Inputs" shows that the WOT switch is ON and your Idle switch is OFF... It should be the other way around if you are trying the adaptation. It should be idling... Was that screenshot taken during idling??? If so your switches are backwards.
Old 10-20-2006, 01:12 AM
Wachuko
Wachuko's Avatar
Question
When I click on Inputs they do not show... it is not until I turn off the car that the screen you see there shows up... so to answer your question, the car was off (but switch on) when I took the screen shot.
I turn on the car... press inputs, nothing... shut of the car Inputs screen appears with those values How long does it take your Input screen to display? Do they come up while your car is idle??
Quick Reply: Scantool Diagnostic Interface Results Thread
