Broken clutch fork?
Broken clutch fork?
So I am having some problems shifting and getting into gear.
here are he symptoms:
The pedal feels funny even after bleeding, it has more travel before resistance and it is softer.
I cannot shift into any gear with the engine running.
If I try to push the pedal further to the floor I hear a grinding sound, not unlike the shift fork engaging the ring gear.
The roll pin is still in operation.
The master and slave cylinder have been recently replaced and show no signs of leaking.
Are these symptoms of a broken or cracked shift fork? How could I tell without disconnecting the engine from the transmission?
Is it really possible change the fork out without dropping the engine?
thank you in advance
Ken
'89 C4 Coupe
'88 Mazda MX6
Ken
'89 C4 Coupe
'88 Mazda MX6
Technical Guru
(although unlikely...)
There is also an inspection port on the bottom of the transmission bellhousing meant for checking the amount of clutch disc wear but you should be able to look through it and check the front of the ring gear for score marks.
Thank you for the ideas, I will take a look in the inspection port and readjust the pedal travel. Hopefully I did not do too much damage.
The clutch has about 16k miles on it and the fork and associated hardware are also listed as being replaced by the PO's mechanic.
If the pedal was incorrectly adjusted so the release bearing was always engaged I guess that would explain the disintegrated bearing there.
I will keep everyone posted on any progress.
take care
Ken
'89 C4 Coupe
'88 Mazda MX6
take care
Ken
'89 C4 Coupe
'88 Mazda MX6
It turns out my pressure plate was cracked:
https://rennlist.com/forums/964-forum/322497-cracked-pressure-plate.html
Everything came out without too much trouble, a stuck PDAS actuator and rounded out cheese heads were the worst.
The release bearing was still in good operating condition and spun nice and smoothly. The release fork was also fine and the bushings were operational although they required some pounding to remove the operating shaft.
Ken
____________
'89 C4 Coupe
'97 Volvo 960 Estate
Ken
____________
'89 C4 Coupe
Just saw Jason's pic of the broken transmission (pic from bell housing end)...
This is exactly what mine did - clutch fork pivot bearing seized, spun inside the transmission 'ears' and finally broke one...
My mechanic / me are having a tough time getting this sorted:
- can't source a replacement front trans casting
- can re-weld though don't have the dimensions to re-machine
- complete replacement trans seems a bit of a waste...
Any ideas?? Anyone have dimensions for re-machining the shift fork pivot??
Thanks much,
andrew
Thanks much,
andrew
What our local welding shop guy did was pretty clever. He asked me for an old, junk release fork pivot axle. He put it in position, then just welded around it. Aluminum weld does not stick to steel. Then he justed pulled out the junk axle, and voila, we had a correctly sized hole. No machining. It works fine.
Technical Guru
Here are some photos of the welding with a little dremel tool grinding but before the boring.
and here is the TSB from Porsche.
