Clock question
Seared
Clock question
I've posted this question on the 993 forum with limited success in the past. Hopefully one of you can assist.
On the rear of the standard 964/993 clock, which connections are for:
- Power
- Ground
- Advancing the time
I'm not concerned with the warning light connections or any of the bulbs. This is for a project.
Andreas
- Power
- Ground
Andreas
Technical Guru
There are two connectors on the back of the 964 clock.
The pin for advancing the clock is on the smaller of the two connectors, with the brown/green wire.
On the larger connector power is provided on pin 4 (red) and ground is pin2 (brown). In a Porsche 964/993 brown is always ground.
