964 Forum 1989-1994
Driver side front oil leak?
Old 03-29-2006, 09:34 PM
thedyingiraffe
thedyingiraffe's Avatar
Question Driver side front oil leak?
What is there that could leak oil close to the front wheel? I know the oil cooler is on the left side..
Doesn't smell like brake fluid, but I'm not sure 100%. Anything else?
Hydraulic shocks maybe? Please don't tell me I'll have to get bilsteins HD's and lower my suspension??? Noooo
M-A
'91 963 !
Old 03-29-2006, 09:43 PM
jimq
Burgled
jimq's Avatar
powersteering fluid
Old 03-29-2006, 10:06 PM
eddychan
eddychan's Avatar
Check the colour, if it is redish colour then it will be power steering fluid. You should know brake fluid is clearer than you oil...
Eddy
91 C2 Tiptronic
Old 03-29-2006, 10:29 PM
Eggplant Cab
Eggplant Cab's Avatar
Also check under the car to see where it's leaking from. If it's in front of the wheel well, etc. It's easier to diagnose that way.
Old 03-29-2006, 11:02 PM
JerryW
JerryW's Avatar
Just behind the front wheel arch is the breather for the brake fluid res. If you topped up the brake fluid or bled the brakes this might be the problem.
Old 03-30-2006, 01:19 AM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Its been awhile but I think the Boge shock oil was green?
Old 03-30-2006, 02:01 AM
stevepaa
stevepaa's Avatar
I am ignorant on this. Is there a cooler for the power sterring fluid up there? I thought my oil cooler was up there.
Old 03-30-2006, 04:53 AM
boubi
boubi's Avatar
Originally Posted by stevepaa
Is there a cooler for the power sterring fluid ?
No !!!
Old 03-30-2006, 07:51 AM
jimq
Burgled
jimq's Avatar
the steering racks are crap and leaking seals arent all that uncommon. Look around the boot on the steering rack at the ends and see if its wet. The under tray makes it hard to see but if it is the tray up front will be wet.
Old 03-30-2006, 08:53 AM
DavidI
DavidI's Avatar
If it's a C4 then oil from the front diff can run across the undertray and appear behind the wheel arch.
Quick Reply: Driver side front oil leak?
