964 Forum 1989-1994
Sway bar- advice please
Old 09-05-2005, 02:57 PM
Pesty
Pesty's Avatar
Default Sway bar- advice please
Hi,
On the meet in wales last month someone metioned(ROBMUG?) that to reduce understeer on a C4 people fit an adjustable sway bar.
I have just done a search and people seem to fit a larger one on the rear on its hardest setting.
some questions that I couldnt see an answer for.
1) can somene in simple terms explain just what is a sway bar
2) is it home fit job or do I have to take it somewhere
3) do I need to get alignment done afterwoods
4) how much will it reduce understeer.
5)where do I get one from in the UK.
sorry thats a lot of questions that I'm sure you are all bored of answering
Old 09-05-2005, 03:23 PM
Pesty
Pesty's Avatar
ok I ve just seen on one website that sway bars dont effect castor etc etc so no set up is required its just a streight swap. looks like a simple enough job ( if anything is simple on a 14 year old car)
Old 09-05-2005, 03:33 PM
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Adrian's Avatar
C4 people who do not go racing (most) fit 21 or 22mm fixed rear sway bars to their 964s to reduce understeer. An old and proven solution. There is no justification for fitting an adjustable sway bar on a C4 for normal road use.
Another word for a sway bar is a stabiliser bar or anti-roll bar.
Ciao,
Adrian.
Old 09-05-2005, 04:16 PM
Pesty
Pesty's Avatar
thanks Adrian.
Old 09-05-2005, 04:21 PM
Youcef
Youcef's Avatar
I fitted a 21mm bar (amoungst other suspension mods) on my C4 as Adrian suggested and was very happy with the result. It is a simple job that you can do at home and would take about 2 hours. I would find it hard to scale the understeer reduction as I changed to stiffer springs, different camber and wider front tyres at the same time so I covered most mods to reduce understeer. There are a great many articles on this subject and is also covered in great detail in Adrians book (where I referenced most mods). Also look into the the 5mm spacers with 225 tyres on the front as this helps reduce understeer greatly also. Good luck.
Old 09-05-2005, 04:41 PM
Pesty
Pesty's Avatar
doh didnt even think about looking in the book ! I'll fish it out.
If you don't mind me asking where did you get it from?
I have found this but at 300 ish euros its a bit much. FVD list fixed rear only for the C2
http://www.cargraphic.com/index.php?...,1529/&start=0
Old 09-05-2005, 04:51 PM
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Adrian's Avatar
The 21mm is fitted to the 1990 Carrera 2 only. The 22mm is fitted to a number of 964 verions. I am pretty sure they are in the book.
One of the UK based parting out places would be a good place to start.
I have a set of RS America sway bars in my basement but the overall cost including shipping would be high.
Ciao,
Adrian.
Old 09-05-2005, 04:52 PM
RSAErick
RSAErick's Avatar
I have the 21mm fixed rear sway bar for sale, if you're interested.
Old 09-05-2005, 04:54 PM
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Adrian's Avatar
21mm is best so I would take up the offer.
Ciao,
Adrian.
Old 09-05-2005, 05:00 PM
Pesty
Pesty's Avatar
PM sent. Thanks all.
Old 09-05-2005, 05:02 PM
burgass
burgass's Avatar
Adrian
Is the front RS America sway bar adjustable and will it fit on a C4? If yes I am interested!!
Pesty I have a 21 mm also in case the shipping costs from Erick are too high. By the way IMHO this is the first thing you have to change on a C4
Cheers
Old 09-05-2005, 05:45 PM
Christer
Christer's Avatar
Burgass
Why not fit the front RS sway? Why the RSA (just out of interest)?
Old 09-05-2005, 05:49 PM
burgass
burgass's Avatar
I was with the impression that it will not fit on a C4!! Does it?!?
If it does I will certanly do that
Wonder if somebody has done that...
Old 09-05-2005, 05:52 PM
Christer
Christer's Avatar
I am pretty sure it does, as the C4 has the same servo setup. On the C2 its a f***ing close fit.....ask me how I know....
Old 09-05-2005, 06:04 PM
burgass
burgass's Avatar
Thanks Christer!!! Will start searching for info and solutions
Problem with the C4 is that you have yhe "extra" drive shafts making life a bit more complicated
Quick Reply: Sway bar- advice please
