964 Forum 1989-1994
need button caps for a/c, defrost & recirc
Old 02-24-2012, 08:55 AM
Enso
Enso's Avatar
very helpful for me i'm missing the same *****
thanks for this info
glenn
Old 02-24-2012, 10:11 AM
creaturecat
creaturecat's Avatar
Originally Posted by 911Jetta
Mine too! I was hoping I could just glue/tape it in place...now I know better.
Huge thanks for the DIY you created.
I used crazy glue. So far, 6 months later, all is well.
Old 02-24-2012, 04:02 PM
Laker
Laker's Avatar
I tired crazy glue, at first it didn't hold. When the button's insides break away, there isn't much left besides an empty shell to glue to. After I did the replacement, on the old switch, I tried crazy glue again- this time I glued the switch up and 'off' whoops Maybe warm Fun-Tak inside the button would do a nice job of holding it in place, or something more commercial/permanent like caulk. I paid $144+tax for the double switch.
Old 02-25-2012, 03:42 AM
RicardoD
RicardoD's Avatar
Great write up, my buttons need replacing on my C4, I love to figure out how to refinish the buttons
Old 02-26-2012, 04:19 PM
stevepaa
stevepaa's Avatar
nice writeup
i pulled mine to find my klinking noise and decided to inspect that little fan, it was full of dust, the tube had dust in it and the probe was off center.
i cleaned the spindle with kleenex dampened with graphite spray and fan works quite nicely now.
thanks
Old 02-26-2012, 09:27 PM
Laker
Laker's Avatar
Originally Posted by Laker
... I pulled off the air sampling fan at the rear, and blew out the cobwebs from the rubber tube that runs the length of the CCU......
yeah, it gets nasty in there
Old 02-28-2012, 12:25 PM
Goughary
Goughary's Avatar
I just went to order part number: 944-653-921-00 and was told it's 129 dollars for the switch? Does that sound right? Am I ordering the wrong part? Sometimes I just cant understand how it's possible that they can charge that much for something so simple...
Old 02-28-2012, 12:31 PM
GeorgeK
GeorgeK's Avatar
And you're lucky to find it so cheap. Costs much more in Europe.
Fine example of the factory supporting its air-cooled roots ... not.
Old 02-28-2012, 01:20 PM
Laker
Laker's Avatar
Yeah I paid a little more, but do see it on Sonnen for that.
You have to make sure it's the exact same double (Defog/Recirculation) button as the CCUs varied slightly.
Anything 'fan' related is very expensive it would seem
Old 03-20-2012, 11:24 AM
993James993
993James993's Avatar
Hi Laker,
How were you sure about the part number? Is it simply a matter of ordering the switch based on your car's model year?
Were the contacts simply pressed in? No soldering?
Thanks for the write up. I need to do this for both switches.
Old 03-20-2012, 12:21 PM
Laker
Laker's Avatar
If your CCU has two buttons on the right, with the upper being recirculation and the lower being De-fog / De-frost windshield, it's the right part number. The single part contains both switches. (Re-circ & De-fog) They plug right into the green board (no soldering). You can see the slots on the right and left edges of the green board.
Old 03-20-2012, 10:29 PM
993James993
Thanks Laker! Yesterday the switch cover fell off the main power button so now I need to order both switches. I'm tempted to look for a used CCU but it would likely have the same issue. I'll likely go to Sunset as they have always treated me good.
Old 03-20-2012, 11:36 PM
dfinnegan
dfinnegan's Avatar
Wow, that part is now $130! Guess I should have bought back when it was only $68!
I'll just have to wait until it's *really* expensive :-)
Old 03-21-2012, 03:12 AM
hamah
hamah's Avatar
Laker, you need to somehow get these DIYs you put together put in the DIY section so 10 years from now it's easy to find. How will I ever find this useful info under a subject "need button caps for a/c, defrost & recirc"? Thanks
Old 03-21-2012, 10:57 AM
993James993
I concur. It took me forever to find this thread. The search function did not work and I later realized that by luck I had subscribed.
Quick Reply: need button caps for a/c, defrost & recirc
