momo steering wheel install - looking for clarification
</font><blockquote><font size="1" face="Verdana,Tahoma,Arial,Helvetica,Geneva">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Originally posted by Eric in Chicago:
<strong>Thanks Guys,
I am going to have to take the wheel off again and look. I dont think I have the sloted hole. I will check it out. On my clock spring (the round donut that fit under the stock wheel had a wire harness comming out the top running to the 2 orange clips under the dash. my guess is one of those 2 sets of wires was the horn control. I will pull the wheel and look for the sloted hole.
Thanks for the response!</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">
Just a heads up for others doing this. I had to with a decent amount of force press the new horn contact into it's location. This was to get the hooks to "pop" through. Well they didn't pop through but sheared off....D'oh!
After installing the wheel, the copper ring on the momo hub was not making good contact with the horn contact on the column. I had to pull it out slightly...so now I'm wondering if the contact shouldn't have been pressed in at all (but it is working now).
King of Cool
<strong>...Momo Usa,Racers Group,Kelly Moss,Midwest Eurosports and a couple of dealers had no idea how to get the horn working on my Momo GT3R wheel
Thanks in advance</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Eric,
I'd be interested how you managed to solve this (if you did...).
I also have GT3R wheel & horn doesn't work...
Thanks!
Thanks!
I pulled the wheel again today. The 993 hub looks the same as the 964. There is a slot at one o clock. My guess is that I can use the same horn contact. Thanks for the help
I hope you guys dont mind a 993 guy comming over here (Joey Bagadonuts said it would be ok....)
Thanks again for the help!
King of Cool
<strong>I pulled the wheel again today. The 993 hub looks the same as the 964. There is a slot at one o clock. My guess is that I can use the same horn contact. Thanks for the help
Thanks again for the help!</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">Eric,
Could you let us know wheather this does it or not, thanks.
<strong>(Joey Bagadonuts said it would be ok....)</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Arial,Helvetica,Geneva">You bet! Always glad to see the king <img border="0" alt="[king]" title="" src="graemlins/r.gif" /> of mods making a contribution.
Good seeing you today at the PCA gathering. Sorry I didn't have a chance to hear your latest plans for the red rocket but Jeff told me you're going with a full cage! Cool!
Hi just wanted to revive this thread by asking a question (sorry if it sounds stupid) but I was told by my mechanic that MOMO MO-7004 adaptor won't work. The little part that protrudes out from the main thing (in red line as seen in the other photo attached) is bigger than the original slot. Also there should be a small circular ring that fits in the circular slot on my steering rack which is also missing.
Any clues or is he mistaken?
The black clock spring assembly in your first picture has to be removed. You need to buy one of these contact pins, part # 964.652.104.00
It'll look like this installed.
Then, your Momo hub goes right on.
So I have this part. And the momo hub slides on top of it. there is only 1 wire inside my hub. I assumed the horn grounded itself to the ring it installs into, but the horn isn't working. So I guess I am wrong. What am I missing?
I tried grounding the steering post to the # 964.652.104.00, and nothing happened. The fuse for the horn is good. So something is amiss...
momo / ****
I'm putting (attempting to) a Momo steering wheel on my airbag '91 964. Wheel off and down to this part...I've removed the stock horn contact ring and directions (found here) say to "disconnect" the wires going into the back of the ring. 2 are for horn and 1 for airbag I believe? I cannot figure out how to disconnect- I can only see cutting these wires. Can anyone help me please ? Thanks in advance. - Andy
First make sure battery is disconnected, take the key out of the ignition you dont want to turn it at all and dont use steering lock to hold the wheel when tightening/untightening
the connectors for clock spring are behind the dash, might be tied down with a zip tie they are probably bundled in with the column switch wires
\Might be easier if you take the column shroud off
Thank you very much for your reply. As you can see, I pulled wires out so I could disconnect them. I thought they disconnected from the horn contact ring itself but no. It's done and I'm so down with end result.
