93 964 Spoiler Part Diagram
Can someone please let me know where I can get a parts diagram for the spoiler on a 92 964. I need to purchase the retractable plastic piece that extends up to direct air into the engine when the spoiler is up.
Thanks guys. There is also rubber flap that covers the engine when the spoiler is down. Can I push my luck and see if you know the part no. for that.
Parts breakdown for 2001 911 retractable spoiler
Hello
Does anyone have a parts breakdown diagram with part numbers (and then idea where to buy the parts ) for the parts in a 2001 Porsche 911 retractable spoiler. Have managed to patch together my lift and retract mechanism. Micro switches are worn and plastic "cable gear Bars" have teeth messed up on the end because microswitches failed and motor continued to run Grinding away some teeth.
Dealer says you have to buy the whole assembly with motor at 1000+ dollars. I only need a two microswitches and 2 cable gear bars.
Hello
http://www.porsche.com/usa/accessori...artscatalogue/ then go to .pdf pages 282-284.
