How to Remove Rear Bumper Face
Old 11-29-2009, 12:43 AM
ducnine
ducnine's Avatar
Default How to Remove Rear Bumper Face
Here is a How To on Removing the Rear Bumper Face.
This is a pretty easy thing to do.
This is what it looks like with the Bumper Face removed. Now time for cleaning.
ducnine is offline
Old 11-30-2009, 12:26 AM
pete000
pete000's Avatar
You can actually just remove the two long bolts holding the whole assembly including the alloy beam as one piece. I found it a bit easier that way.
Lots of cleaning ahead for you, but its worth it.
Looking good so far.
pete000 is offline
Old 12-01-2009, 06:51 AM
TL-Register
TL-Register's Avatar
Wasn´t it fixed there ? If not, someone took it off before ...
wide Regards
Norbert
TL-Register is offline
Old 12-01-2009, 08:16 AM
ducnine
ducnine's Avatar
good point. There were some holes on that area of the bumper face and I might have broken them a bit. i'll post pics of that area sometime.
ducnine is offline
Old 12-01-2009, 12:36 PM
TL-Register
This part is fixed with rivets ( hope this is the right word ) under the middlepart.
Norbert
Old 12-01-2009, 05:38 PM
joey bagadonuts
joey bagadonuts's Avatar
Correct.
joey bagadonuts is offline
Old 12-01-2009, 06:58 PM
ducnine
ducnine's Avatar
Awe crap! :
All the previous little snipets I read about bumper removal never mentioned this little tid bit!
ducnine is offline
boxsey911
boxsey911's Avatar
Are people saying that the bumper face (rear PU) is rivetted to the reinforcement bar? And therefore the reinforcement bar should also be removed as per Pete's additional instructions above?
boxsey911 is offline
Old 12-02-2009, 05:54 AM
TL-Register
No need for that ! The rivets must be drilled out after removing the rear light middelpart ( carefull without braking the noses ... )
wide Regards
Norbert
Old 12-02-2009, 10:40 AM
elbeee964
elbeee964's Avatar
Let's assume you have a bone-stock 964 still having those 5 bumper rivets:
1) If you were of a mind to leave them in place, does someone know of a DIY "rivets stay in place" bumper removal thread?
or,
2) You drilled out the 5 rivets' heads for bumper removal. Is there a noticable sloppiness to the bumper upon its "no rivet" reassembly? (Or, any other downside?)
elbeee964 is offline
Old 12-02-2009, 02:59 PM
TL-Register
or,
to 1. : it is impossible without damaging parts! You cant remove the heatshealds to reach the scews of the reinforcementbar.
to 2. : there is no problem to drill them out if you drill slow and keep it cool .
... and no problem replacing the rivets . Tey are standart - available in every carshop with the necessary tool.
wide Regards
Norbert
Old 12-28-2009, 04:29 PM
pete000
pete000's Avatar
I always remove my rear bumper with no issues and have never drilled out any of the factory rivets. I see no need to ever drill them out unless you want to get the bumper cover off of the alloy carrier beam. Save your self some time and just leave them intact. Rear bumper removal should take about 15 minutes requiring no power tools or drill bits.
pete000 is offline
Quick Reply: How to Remove Rear Bumper Face
