The rebuild begins ...
Old 09-24-2005, 12:47 AM
sundog
sundog's Avatar
Default The rebuild begins ...
Today began the DIY rebuild of my 1991 C2 engine. As some may recall this project was made necessary upon finding a large amount of bearing metal in my oil filter.
I am going to keep written and visual records of the process, as this is my first engine rebuild since I rebuilt the 4 cylinder in my peugeot 504 back in the late 70's.
Should I post progress as I go, post a large DIY when I'm done, or just make info available to people upon request?
1st set of pics, preparing to remove engine per Adrian's book. Better quality photos when the wife gets back from Hawaii, these are from my phone.
sundog is offline
Old 09-24-2005, 02:54 AM
carmelo
carmelo's Avatar
Default Rebuild
Post as you go please!
carmelo is offline
Old 09-24-2005, 03:27 AM
Bill Wagner
Bill Wagner's Avatar
Out of curiousity, how many metal shavings were in the filter. Also, when you changed the oil, how many were on the magnetic drain plug?
Bill Wagner is offline
Old 09-24-2005, 05:15 AM
Geoffrey
Geoffrey's Avatar
You'll probably want to get a better engine stand that the one in the picture. The flat-6 is very wide and a stand with two front feet works better as you rotate the engine over. The single front wheel stand may tend to want to fall over. Also, the P201 engine yoke is invaluable.
Geoffrey is offline
Old 09-24-2005, 10:32 AM
sundog
sundog's Avatar
When my tech opened the filter as I requested, there were about a sugar packet's worth of small metal shavings in the filter. I drove the car home, and will check the plug today or tomorrow.
sundog is offline
Old 09-24-2005, 10:38 AM
sundog
sundog's Avatar
Thanks for the advice, the stand seems like it's a little unstable. I have bought an engine stand adapter ring to use with a standard engine stand. It can be found at, LINK . Of course no affiliation.
sundog is offline
Old 09-24-2005, 01:59 PM
bhensarl
Jarhead
bhensarl's Avatar
Please do post the pictures as you go, in this thread, that way we can send it off to the DIY forum when you get done!
Brian
bhensarl is offline
Old 09-29-2005, 04:20 PM
sundog
sundog's Avatar
Today the engine came out. Not too difficult, just a lot of little connectors and hard to get to bolts.
It looks like there's no way all of that fits into that little car!
Note the bypass pipe.
sundog is offline
Old 09-29-2005, 10:48 PM
dkeen
dkeen's Avatar
About how long did it take you to disconnect everything and get the engine out?
dkeen is offline
Old 09-29-2005, 10:49 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Yes, please post as you go.
Wow - that is a huge engine in that itty-bitty little space, isn' it?
Marc
Marc Shaw is offline
Old 09-30-2005, 12:24 AM
sundog
sundog's Avatar
I did it in about 7 hours, over 3 nights. One night to jack up the car and get it on jackstands, lots of repositioning of the jack stands, and reading posts to get it right (2 hours). The second night, with my daughter to disconnect everything in the engine bay (3 hours). And today disconnect everything under the car, and drop the engine (2 hours).
There were a number of trips to the store to get the appropriate tools for the job, hex sockets, impact wrench, larger oil pan, towels (lots of towels). Additional time standing reading Adrians book (excellent reference), and the porsche workshop manual, trying to figure out what the **** they were talking about . Oh, yea, and having to adjust the height of the rear of the car to actually get that engine out, drop the front off the jackstands, and lift the rear 2" more, that took an hour.
I also spent a lot of time in cleaning things to get access to parts, lots of oil leaks and grime.
sundog is offline
Old 09-30-2005, 02:13 AM
bhensarl
Jarhead
bhensarl's Avatar
Man, I'm so jealous. That looks like fun.
Brian
bhensarl is offline
Old 09-30-2005, 04:38 AM
Euromagination
Euromagination's Avatar
Wow. This is gonna be a good thread. Keep up the posting and pics.
Also, if you dont mind me asking... at what mileage is the motor?
Euromagination is offline
Old 09-30-2005, 10:02 AM
dkeen
dkeen's Avatar
Hi Sundog,
I have been toying with the idea of dropping the engine in my 964 for about a year now. But it always seemed like such a daunting task, that I have not followed through.
Now if you don't mind, I'd like to pass several questions by you since it is all so fresh on your mind that have been bugging me about it.
Do you think someone with good mechanical skills and persistence (but little experience with major work like this) can do this? Half of me (the scared half) says take it to the shop. The other half loves the challenge.
Also, I have a jack and stands. From reading Adrian's book it sounds like I should be able to balance the engine on the jack. Did you find this difficult? I noticed you bought the adaptors for the jack to help with balance, but it really seems precarious and seems like an engine stand is needed.
Do you need to put the front of the car on stands (considering you had to take it off the front stands to get the engine out)?
How high does the rear of the car need to be to get the engine out? Were the jack stands at top height enough?
Did you end up supporting the car with the rear jack stands where Adrian suggests in his book?
Where did you get your copy of the Workshop Manual and did it really help? (all I can find are CD versions and hard copies that cost $800).
Can you please list the "special" tools that you needed to complete the job? I have metric sockets, etc. Just want to know if there are any big ticket items I need to consider before embarking on this journey.
What potential pitfalls did you encounter, or what should I be wary of?
Once the engine was out, how do you move it around? If its still on the jack, how will you now work on it?
Good job and please keep us posted.
Dave
dkeen is offline
Old 09-30-2005, 10:36 AM
greenjt
greenjt's Avatar
Hey Dave... Let me know if you go forward with this. I'd be interested in lending a hand for the experience.
I'm in Wakefield - in what part of town are you?
greenjt is offline
Quick Reply: The rebuild begins ...
