Aiming your MA Shaw fog lights
Super Duper Moderator
I was working on my P-car yesterday ("playing" my wife calls it) and I finally got around to fixing my fog light.
If you recall, the MA Shaw fog lights/cooler ducts cannot be aimed (see here for details https://rennlist.com/forums/showthread.php?t=197828).
At a distance of about 15', the right light ended up about 1' higher than the other (what is that? 24 degrees?) and bugged me.
I drilled into the metal backing plate behind where the fog light is screwed in and installed 2 small stainless steel screws. By turning the screws in or out, I can now aim the light up or down (ie. turn the upper screw out and lower screw in, the light is aimed down, etc.).
You can see the screws in the photo behind where the fog light is screwed in.
Hope this helps anyone installing these.
Marc
p.s. Perhaps Brian could add this to the end of the DIY thread.
Marc
