Individual Throttle Bodies / 951
Old 03-21-2017, 10:50 AM
raleighBahn
raleighBahn's Avatar
Default Individual Throttle Bodies / 951
Hey folks,
Was looking at a nice summary video on individual throttle bodies at
Wondering if this has been tried/discussed in the 951 community? My very limited understanding is that it would not necessarily produce more horsepower (or perhaps less). However, one of the primary challenges of the 951 is throttle response, length of intake runners, and etc - this would seem to be the solution. Another challenge is fitting various 3rd party turbos under the intake, which this could solve too. Lastly, many leaks (loosened connections) are under the manifold, so removing it would have some operational benefits.
Our throttle bodies are already mechanical, so it seems an array of four smaller throttle bodies could be driven from the same cable. As per the video, the fabricating would be some kind of coupler to the cylinders with vacuum ports. Thought would be needed as to how to filter the air on the inlet side and not give up the complete benefit of freeing space up.
Old 03-21-2017, 10:56 AM
Voith
Voith's Avatar
I wanted to go with turbo+ ITB's but eventually changed my mind. The more I read about it the more I didn't want the extra complication.
This thread gives some clues on itb turbo setups: http://www.motec.com/forum/viewtopic.php?f=39&t=401
The challenge with ITB throttles and turbocharging is that there will be a difference in airflow at different throttle positions but the same boost pressure. This means that the air fuel ratio will change if not accounted for. There are several different strategies that can be employed and will depend on the particular engine. You need get a stable MAP signal using a manifold chamber box to be able to use MAP for any type of correction. I like to use a main fuel table based on TPS and RPM and a secondary table based on MAP and RPM or TPS and MAP to account for the VE differences at different throttle position. I still retain the double pressure double fuel MAP compensation table. I map the engine on the lowest boost setting and get the air fuel ratio correct. Then any changes required are done in the seconday fuel table.
If anyone wants to play I'll sell my hayabusa ITB's for cheap.
Old 03-21-2017, 11:17 AM
V2Rocket
Rainman
V2Rocket's Avatar
Believe Raceboy has ITB's on his 2.5 16v turbo.
Old 03-21-2017, 11:47 AM
AnthonyGS
AnthonyGS's Avatar
I doubt it's worth the effort on a forced induction setup, however on an N/A setup and can lead to lots more hp at high rpm. If you wanted to race an N/A 944 it'd probably be worth it if you have deep pockets.
Old 03-21-2017, 11:55 AM
Humboldtgrin
Humboldtgrin's Avatar
Didn't Porsche use ITB on the 1981 924/44 LeMans 2.5 turbo?
Nice intake.
Old 03-21-2017, 12:05 PM
Voith
Voith's Avatar
It can be done but as I understand it, it's mediocre tuner's nightmare.
I'm not experienced tuner so I'll rather take the KISS aproach and complicate my life with ultra short path chargecooled setup instead.
Old 03-21-2017, 12:29 PM
V2Rocket
Rainman
V2Rocket's Avatar
^^how's that coming?
Old 03-21-2017, 01:10 PM
odonnell
odonnell's Avatar
Engineering Explained has a good video on ITBs, on youtube. It won't necessarily make more power on an NA car either. You will get better throttle response though.
Old 03-21-2017, 01:20 PM
Voith
Voith's Avatar
I've hacked everything up now it needs to be welded but since angle and size is critical, I'll have it welded when I test fit engine in engine bay.
I'll use stock 951 TB and it will be the only thing between turbo and plenum/chargecooler. No pipes.
Old 03-21-2017, 09:13 PM
944crazy
944crazy's Avatar
Nice intake.
Nope...you can see the single throttle body in the normal position.
Old 03-21-2017, 10:19 PM
Humboldtgrin
Your right I need glasses.
Old 03-21-2017, 10:45 PM
Voith
Voith's Avatar
GTR has them.
Old 03-22-2017, 11:29 AM
gruhsy
gruhsy's Avatar
There were some post by Michael Mount of his throttle bodies. Very nice looking pieces. I think some RL'ers bought some of them. Would love to see and hear more about his.
Lindsey Racing also has an ITB thread on here if you search for the past thread.
Old 03-22-2017, 01:25 PM
MAGK944
MAGK944's Avatar
Never seen a MM 951 build using itb's, he did a really nice na build a while ago.
Old 03-22-2017, 01:39 PM
gruhsy
gruhsy's Avatar
He built the throttle bodies only....and posted them on here. They were for the 16V head. He didn't build any 951 engines for anyone using them in a turbo. If you search this forum there are some nice photos of them
Quick Reply: Individual Throttle Bodies / 951
