need help in identifying what goes in....
Old 02-13-2017, 10:28 PM
smkn951
smkn951's Avatar
Default need help in identifying what goes in....
hello everyone,
i am in the process in putting my engine back together. i took it apart due to a blown head gasket.
i decided to pull the engine out and redo all the seals. cam tower, valve seals valve stem guide, water pump gasket etc...
well long story short, i am putting it back together while intsalling the oil fill tube, i noticed on the bottom right of the oil fill assembly on the block that there seems to be another hole...does anyone have a picture on what goes right there?
TIA
Carl
Old 02-13-2017, 11:04 PM
raleighBahn
raleighBahn's Avatar
IIRC, nothing at all. I believe it had some use in the factory only, during production. You might post a picture, but I think I know exactly the one.
Old 02-13-2017, 11:23 PM
smkn951
smkn951's Avatar
i impatiently dropped the engine in already , but i managed to find someone else's pic. highlighted is the hole in question.
Old 02-15-2017, 08:46 PM
dp951
dp951's Avatar
Default David Pagan / engine block
Hello,
There should be a plug inserted into that lower hole if it was removed bottom right .
Old 02-15-2017, 11:14 PM
V2Rocket
Rainman
V2Rocket's Avatar
Nothing goes there - it is a blind hole. I guess you could plug it.
Old 02-16-2017, 01:02 AM
dp951
dp951's Avatar
Default David pagan / Engine block plug
oem pic nice and dirty ( note silver plug)
Old 02-16-2017, 08:56 AM
Jay Wellwood
Jay Wellwood's Avatar
Cool
I recognize that photo.
Old 02-16-2017, 11:47 AM
smkn951
smkn951's Avatar
thanks everyone.
i don't recall taking any plug out at all. all i did was cleaned the engine.
do i need to plug it?
TIA
Carl
Old 02-16-2017, 05:59 PM
dp951
dp951's Avatar
Default David Pagan / Take your time
Good luck on the build its always best to double check and take your time , you as good as your last mistake .
This Guy shouldn't have been in such a Hurry to drive through the puddle.
Old 02-16-2017, 06:12 PM
V2Rocket
Rainman
V2Rocket's Avatar
holy ****
Old 02-16-2017, 10:20 PM
Jay Wellwood
^ What he said!
Old 02-16-2017, 11:42 PM
smkn951
smkn951's Avatar
Of all things to forget......ahhbhh!!!!the hose going to the aos connected to the bottom is laying in the parts box.... now I gotta tear down the exhaust again 4 for the 4th time.....
Old 02-17-2017, 01:40 AM
mel_t_vin
mel_t_vin's Avatar
Turbo drain vent line?
Old 02-17-2017, 10:57 AM
smkn951
smkn951's Avatar
other colorful words spewed out my mouth but turbo vent line wasn't one of them.........lol
Old 02-17-2017, 11:45 AM
V2Rocket
Rainman
V2Rocket's Avatar
just as a note regarding the mystery hole...
if you look at towards the front of the block, underneath where the AC/alternator bracket goes, you'll see another identical hole to the mysterious "behind the AOS" hole.
Quick Reply: need help in identifying what goes in....
