Hot idle issue ?
Old 01-27-2017, 08:42 AM
blade7
blade7's Avatar
Default Hot idle issue ?
Having a hot idle issue, cold start, cruise and boost AFR's are all ok, but coming to a stop when the engine is hot the AFR goes to 16 or more and the idle starts hunting. Tried isolating the ISV and hot idle seemed to improve but AFR everywhere else was rich. Planning to pull the inlet manifold to check hoses and ISV unless anyone has any other ideas ?
Old 01-27-2017, 10:57 AM
shortyboy
shortyboy's Avatar
i would check tps and any rubber couplers/hoses. Could have cracks and when hot, it would expose leaks.
Old 01-27-2017, 11:58 AM
blade7
blade7's Avatar
Yes thanks. Probably do the throttle body seals while I'm there. Been having similar issues on and off for years in slow moving traffic.
Old 01-27-2017, 02:01 PM
GPA951s
GPA951s's Avatar
Check the top or Throttle body the Idle Screw, maybe the rubber O ring is perished...Other than that.. Get about 15 feet of bulk silicone hose and look at LR website Good Vacuum Diagram.. 30 year old rubber.. Toss it.
Old 01-27-2017, 02:27 PM
Ski
Ski's Avatar
TPS and check the vac hose under the throttle body, follow it back. Good suggestion on the Idle Screw o-ring as well.
Old 01-27-2017, 02:47 PM
blade7
blade7's Avatar
Good suggestions. A while back I cable tied on all the small dia hoses I could see. Perhaps there's more out of sight.
Quick Reply: Hot idle issue ?
