Head Stud Question
Head Stud Question
I'm getting ready to install new head studs into my fresh block. What is recommended to be applied to the threads from the stud to block? I've read, liquid pipe sealant, Loctite, heavy grease.... what is best? what brand?
Do NOT use Loctite! The Loctite instruction sheet will tell you why.
Use Extreme Pressure Lube https://www.summitracing.com/parts/d...fLUaAu598P8HAQ
I saw those instructions when you posted last time -- i.e., that you need to tighten before it hardens (which, of course, a non-robot could never do). I wonder if that's why the factory seemed to use an excessive amount of the stuff -- so that it would stay wet long enough for the factory to get the studs in, the gasket and head on, and the nuts torqued? Even with automated process, it seems like that would take a bit...? Just seemed like they used way more than actually needed, and have always wondered why.
I imagine with an automated system, the studs go in (all 10 at once?), the head and gasket go on, and the washers and nuts get torqued as a unit. It COULD be a short time overall....
Last edited by michaelmount123; 01-12-2017 at 10:54 AM. Reason: 2nd thought noted above
There's no wait time after application. Use the factory torque spec if you're using a factory type head gasket. If you're using a Cometic, use the factory sequence and torque the nuts to 65-70 ft. lbs. in three steps. Fourth step is to go over the sequence a final time at full torque since the embossing on the Cometic slowly compresses and you might find the center studs loose.
There's also benefit in being able to easily remove the head studs next time the engine is apart.
One bottle seems like enough. I ordered two just in case.
Just to be clear. Head studs set to 72mm, but what height do the main journal and shorter girdle studs get set to? Using this same High Pressure Lube?
Thank you in advance.
Loctite red is perfectly fine.. If you don't intend to remove them ever again.
Is there really an excessive amount? The entire thread section is covered, but typically no excess. Granted, they're a bitch to remove. //// 1/12/17 second thought: yes, it is excessive since the job of securing the studs could be done with a drop or two of red Loctite rather than what Porsche has done./////
I installed the head and main studs and they look good. I did notice some of the studs on the head side seem like they can spin fairly easily. I don't feel any slop in the thread or wiggle to the stud but it doesn't take too much to spin it with your fingers. I figure stud stretch would help this and I'd imagine if the stud would spin a little when torquing it probably wouldn't hurt, there seems to be enough spacing under the stud to not bottom out if it does.
Pics:
Pics:
Did you use the grease MM recommended to prevent them from turning? You really don't want them to turn when you torque the nuts. They may get too low, you'll alter the turning friction and torque value, and you'll put a lot more wear on aluminum threads in the block.
