Bearing material in oil????
Hi everyone,
Thought I should tell you about a little problem I'm working through.
I did an oil change on the weekend, and found the following in the oil:
Doesn't look like bearing material though.
Fortunately we have a Niton Xray Fluorescence PMI gun at work that can do a chemical analysis on particles of this size:
So it looks as though it is 99.8% pure aluminium foil - probably from the foil cap of an oil change some time in the past!
(the oil I have been using for the last 7 years doesn't have a foil cap)
Any other thoughts?
Cheers,
Mike
Any other thoughts?
Cheers,
Mike
