How realistic to change to Audi 01E gearbox?
Old 11-06-2016, 01:44 PM
  #31
KevinGross
KevinGross's Avatar
Call Roger Brown at California Motorsports. He's had custom 968 transmission parts made in the past, such as a ring and pinion set. Probably made by Albins in Australia but dunno for sure. Good luck!
Old 11-06-2016, 04:55 PM
  #32
FrenchToast
FrenchToast's Avatar
Originally Posted by 333pg333
Seems like there are a few versions of the 01E out there.
There are quite a few, including 5-speed versions. Many are set up for FWD without the rear output shaft.
http://www.elektro.com/~audi/01E/
968 version is mentioned a few scrolls down. Or, here: http://www.elektro.com/~audi/01E/ind3.html
_
I also second the recommendation to contact California Motorsports: https://californiamotorsports.net/
_
Maybe the Audi B5 A4 STW/BTCC Touring cars has gears you can use? Many were actually FWD, and used a sequential transmission. No idea what normal transmission it is based on, if any.
Looks a little different though! According to this post, the gears are all Audi parts: http://www.clubgti.com/showthread.ph...=1#post1690962 . The rest of the thread is mostly about the engine.
Old 11-06-2016, 10:17 PM
  #33
333pg333
333pg333's Avatar
Thanks all for the continuing suggestions. Keep 'em coming. Getting a viable alternative to the stock 968 box without having to spend stupid money on full sequential is very attractive. You wonder why they even made this one 6 speed box just for the 968 rather than modifying something else.
I actually sourced my current gearbox via Roger at CMS. We've spoken briefly in the past about different options and yes, they have sourced alternative gearsets from Albins Down Under. I've already asked Albins if they have any Dog sets for the 968 box. Succinct answer was "No". Might have to ask how much to make one set..I'm guessing a LOT. Even then, not sure yet how possible it would be to adapt the SQS shifter mechanism to this gearbox. So might have to go back down the path of fitting a different gearbox and making it work. All this adds to the potential costs, although perhaps purchasing one of the Audi boxes from Europe sounds cheap enough.
Just had a reply from PPG who say their Dog set was designed for a Transaxle 2wd box. Need to confirm just which box this is for. Maybe someone commissioned a set for a 968 racecar. That would be good..except the ratios may be too short.
Can anyone think of another version of these gearboxes that were used in a Transaxle configuration??
Old 11-06-2016, 11:08 PM
  #34
333pg333
333pg333's Avatar
Just looking at the different ratios for the gears, I wonder how usable these PPG ones would be for us. Anyone have a gearing calculator to hand?
Porsche stock 968 gears
1st = 3.1782, 2nd = 2.000, 3rd = 1.435, 4th = 1.111, 5th = 0.912, 6th = 0.778, Rev. = 3.455 Final drive 3.778
PPG Dog Set ratios
Ratios: 2.545 / 1.500 / 1.200 / 0.913 / 0.750 / 0.666 3.778
Old 11-06-2016, 11:47 PM
  #35
Paulyy
Professional Hoon
Paulyy's Avatar
George D send me this site a while back. For some reason it's not working though.
https://www.cfnmail.com/owa/redir.as...tor-gear-ratio
Old 11-07-2016, 03:06 AM
  #36
sherry66
sherry66's Avatar
This company advertise this audi O1E transaxle gearbox for V8GT40 replicas rated to 700hp here in the UK .
Don't know if it helps ...
Old 11-07-2016, 06:40 AM
  #37
333pg333
333pg333's Avatar
Did a quick calc and something doesn't seem quite right. Either I'm way off or need a custom Ring & Pinion lol...
http://www.cargister.com/calculator-...5d=&teeths%5b2
Old 11-07-2016, 06:58 AM
  #38
Thom
Thom's Avatar
This calculator is completely wrong.
Old 11-07-2016, 09:43 AM
  #39
Raceboy
Raceboy's Avatar
Gee, 2500 UKP? They are indeed capable of withstanding big power but selling 200euro gearbox for more than ten times the price? There are many types of them available, some (A8 2.5TDI ones) have gearbox coolers and there are different ratios, most of them are with quite tall gearing.
Here are some ratios to get the idea:
http://12v.org/urs/charlie_smith/01E/
http://workshop-manuals.com/audi/a4_...nd_capacities/
Old 11-07-2016, 03:23 PM
  #40
333pg333
333pg333's Avatar
Thanks Peep. I'm looking for a Dog set though, so the stock gears aren't applicable. Well except for final drive which I'd prefer to stay with all thing$ considered.
Yes, seemingly Thom although I've had similar results via another online calculator. Something doesn't seem right unless they're designed to work with a different r&p ? I have an editable gear calc sheet somewhere. I'm just trying to see what these gears offered locally look like through the range and what speeds/rpm they offer.
Old 11-10-2016, 08:01 AM
  #41
ealoken
ealoken's Avatar
How did your gearbox serach go?
http://www.samsonas.com/
Ive spoken to samsonas, and they can rebuild your gearbox to a dogbox
Old 11-10-2016, 09:29 AM
  #42
Paulyy
Professional Hoon
Paulyy's Avatar
Albans in AU can do the same thing. The issue is having to pay around 50k to have it done. because then going sequential will cost the same.
If Samsonas can rebuild the box to a dog box for under 10k. Then it might be worth it.
Old 11-10-2016, 09:32 AM
  #43
ealoken
ealoken's Avatar
7000 Euros i think the price was.
Old 11-10-2016, 02:59 PM
  #44
333pg333
333pg333's Avatar
Are you sure they're sure of what version the 968 box is? They might be thinking it's another of the Audi ones?
Old 11-11-2016, 01:25 AM
  #45
Raceboy
Raceboy's Avatar
I know Samsonas, their boxes are quite widely used around here. They are just 600km south from me They change the innards of the box completely, there's no difference if it is Audi or Porsche 01E box.
Quick Reply: How realistic to change to Audi 01E gearbox?
