Project: Race Car
Old 10-02-2016, 03:20 AM
333pg333
333pg333's Avatar
Shame there's no 16v head that can be massaged onto there. Bet it would take some boost!
Old 10-02-2016, 04:40 AM
Paulyy
Professional Hoon
Paulyy's Avatar
It is a shame there isn't. There was a thread on 924.org with a few of them looking for something that's a close fit. Biggest issue was the bolts/studs not in the same/similar spots.
If there was a 16v head that has a bore pitch of 95mm and head bolts/studs in remotely the same place. I would consider it. Running external water and oil lines to the head from the block just adds to the fun of "custom"
Old 10-02-2016, 05:52 AM
michaelmount123
michaelmount123's Avatar
924T head can flow pretty well. This 2L NA engine qualified for a land speed record at Bonneville a few weeks ago in a 924 chassis. Boosted, all the better.
Old 10-02-2016, 06:45 AM
Paulyy
Professional Hoon
Paulyy's Avatar
Interesting setup!
I haven't decided if im going to dry sump the motor just yet.
It really goes to the point in how much work is needed to get the 924 head to flow better?
Here's a cut out of the head for anyone else playing along:
Old 10-02-2016, 04:42 PM
Raceboy
Raceboy's Avatar
Everything can be done but completely stock 924 NA engine has bee proven to hold 350+rwhp reliably on the street (with E85), at ~400whp connecting rod let go (most likely due to 7200 redline after chaning cam).
My turbocharged 924 NA engine back from 2007 still works on another car (at ~300 hp).
My suggestion would be just to overhaul the engine to stock and boost it as is, you can get 300hp easy and get to know the car. Later just add some boost. I would stick to as least amount of custom engine parts as possible when it comes to race car, you never know when you need to source a part quickly. Manifolds, intercoolers etc are no issue, but crankshafts, pistons, custom modified heads etc are a problem if you need a part in few days for example.
Old 10-02-2016, 05:59 PM
V2Rocket
Rainman
V2Rocket's Avatar
Patrick...when are you going to commission some improved 944 engine blocks cast from steel...?
Old 10-02-2016, 06:40 PM
Paulyy
Professional Hoon
Paulyy's Avatar
If i was entering a race series and running every weekend or fortnight then yes i'd keep it mostly stock. But will most likely enter a time attack based event once per month.
Old 10-03-2016, 04:54 AM
333pg333
333pg333's Avatar
There's a few people talking about billet blocks of late. Who knows what's next.
Old 10-03-2016, 04:55 AM
333pg333
333pg333's Avatar
Michael, why the carbs? More reliable than the f/i of the day?
Old 10-03-2016, 01:26 PM
michaelmount123
Sound input based on real world experience. You can't beat that! Also utilizes the KISS principle. Good stuff.
Old 10-03-2016, 02:10 PM
Arominus
Arominus's Avatar
I would imagine its the class rule, LSR is funny like that in the states.
Old 10-03-2016, 02:42 PM
Paulyy
Professional Hoon
Paulyy's Avatar
But where's the fun in building something? ha!
But yes, Raceboy and his mate Pieter (Dutchpug) have really pushed these motors on a stock base with added boost.
Old 10-03-2016, 04:16 PM
Raceboy
Raceboy's Avatar
Here's my 931 track-day car engine. 931 head flows better but you should buy a spare in case you happen to need one. 931 heads in good shape are rare unless you live in USA and it may take a while to find it and then refresh it.
Old 10-03-2016, 05:52 PM
V2Rocket
Rainman
V2Rocket's Avatar
Paulyy,
There is an NA 924 in my local boneyard.
I believe it is 1980 or later.
If you need anything off of it let me know and I can go check it out...
Old 10-03-2016, 11:01 PM
michaelmount123
'Cause carbs make such good horsepower! Simple solution too since it avoids an ECU and all those related i$$ues.
Quick Reply: Project: Race Car
