Refresh951 - Latest 3L Build
Old 04-02-2016, 03:48 PM
refresh951
refresh951's Avatar
Default Refresh951 - Latest 3L Build
Thought I would share about a new build I am doing for a friend.
3L Street/DE Motor
Flanged Sleeved 2.5 Block, 104 mm Bore, Half Filled
Standard 3L S2 Crank
S2 Harmonic Balancer
Crower Rods with Michael Mount Bearing Mod
Clevite Rod Bearings
Custom JE Pistons, 8.0 CR
968 16V Head with VarioCam, Prepped by Michael Mount
Stock 968 Cams
Custom Revline Racing Large Plenum, Short Runner Intake
LR Super 65 Turbo, Modified and Rebuilt by Evergreen
Rogue M Tune
Old 04-02-2016, 04:55 PM
PorscheFanatic202
PorscheFanatic202's Avatar
In the time it takes me to build one motor, you probably will have built 5 if not more. Does the 16v head have ceramic liners like the turbo 8v?
Old 04-02-2016, 05:26 PM
333pg333
333pg333's Avatar
Should be an interesting build Shawn. Looking forward to seeing how it responds with Gustaf's intake w/ the short runners. What's the ETA?
Old 04-02-2016, 05:32 PM
refresh951
refresh951's Avatar
No ceramic liners.
One disadvantage to this motor is that it is not a Hybrid Stroker so the pistons are custom and they will not arrive for about a month. My friend had many of the components already so we are building around them. Still, it should make for a very fun street car.
Old 04-02-2016, 06:50 PM
Jay Wellwood
Jay Wellwood's Avatar
Lucky friend!
Old 04-02-2016, 09:22 PM
333pg333
333pg333's Avatar
I'm interested to see how it responds with the short runner intake and 'not stroker' crank.
I feel we're sort of in a similar position with 16v motors that we were say 5-10 years ago with the proliferation of 3ltr 8v motors and there will be a growing library of data to follow. (Assuming not everyone keeps their cards to their chests). I will be writing about mine soon enough. Are you going to flow the head just for reference sake?
Old 04-02-2016, 09:25 PM
E-man930
E-man930's Avatar
Excellent work as usual Shawn
Old 04-02-2016, 10:29 PM
AlphaOmegaPower
AlphaOmegaPower's Avatar
+1 on the head flow.
What's the rpm range this will be in?
Interested to see how the 16v with this static compression does.
Agree with you Patrick. Lot could be learned looking at different builds with 16v heads.
If things go like in thinking with mine..... I may just invest in a billet block and head so we can infinitely reproduce the block and heads
Old 04-03-2016, 02:12 AM
michaelmount123
michaelmount123's Avatar
Which pistons are you using? I can get you custom JE in around 2 weeks, and I have all the 4V dimensional data. Let me know if you're interested.
Old 04-03-2016, 06:47 AM
Thom
Thom's Avatar
Looking good, but not sure I would want to use a restrictive KKK style hotside with a 16v head and a short runner intake. Would be interesting to monitor back pressure.
Old 04-03-2016, 07:28 AM
Raceboy
Raceboy's Avatar
3.0 16v loves generous turbine housings. Holset HX40 Super with 16cm hotside has full boost at ~3400-3500 rpm with 968 head and Variocam.
No need to choke it with restrictive turbine, it will only make it less powerful but response won't be that much better..
Old 04-03-2016, 10:23 AM
refresh951
refresh951's Avatar
Not my first choice but I think it will do just fine.
Can you post that dyno again of your car so I can see how spool up should be?
Old 04-03-2016, 11:48 AM
Raceboy
Raceboy's Avatar
I have only 2.5 16v turbo, not 3.0 16v.
But here's Jõujaam 968 Turbo (still with S2 non-variocam head), with 16cm2 Holset HX40 Super.
With Variocam head power was still 670hp but with 1.5 bar instead of 1.65 bar and boost treshold was ~500 rpm lower thanks to variocam tuning.
Old 04-03-2016, 12:28 PM
gruhsy
gruhsy's Avatar
Great work again!!!
What work was done at Evergreen to the turbo?
Old 04-03-2016, 12:38 PM
refresh951
refresh951's Avatar
I am well aware of this dyno, still like to see yours.
Quick Reply: Refresh951 - Latest 3L Build
