Bosch 044 Fuel Pump ?'s
Old 03-17-2016, 10:12 AM
NCLA951
NCLA951's Avatar
Default Bosch 044 Fuel Pump ?'s
So I thought with the mild mods I have it might not hurt to update my fuel pump, as I don't know if it's ever been replaced, and it can't hurt to have a better one, so I bought a 044. Of course then I did some research on installing it and the Internet seems to have not reached a decision on whether or not you need to update the wiring and relay when installing it. I'd like to avoid modifying the wiring harness so if I had to I would probably sell the 044 and buy a HV from LR. Also anyone know a good place for metric to hose fitting in LA?
Any direct experience running the 044 on stock wiring and relay?
87 951, 15-18 PSI, stock K26/6, AFM, Max chips, 3bar FPR, Larts SS fuel lines, rebuilt stock injectors, LR DP WG, MBC, 3" with Cat and straight pipe.
Thanks!
Old 03-17-2016, 11:24 AM
V2Rocket
Rainman
V2Rocket's Avatar
Any type of hydraulic hose shop should be able to help...Parker, COMOSO, Hose man, etc.
If you don't mind the drive there is a German metric hose supply place called Hatec in Rancho Cucamonga.
They have awesome prices and friendly people - I bought a 2ft and a 4ft section of -10 stainless oil hose, crimped with my required fittings, for $30 once upon a time.
As far as wiring the pump, I would definitely add a relay just for good measure.
It wouldn't be hard - you could just mount the relay next to the fuel pump in the back of the car, and use the OEM fuel pump wires to trigger the relay coil.
Run a new, larger wire from the fuse box/battery to the relay terminal 87, connect terminal 30 to the pump + and find a nice ground point on the chassis back there.
Old 03-17-2016, 11:38 AM
bw993
bw993's Avatar
I've been running a 044 bosch pump in my 951 with my M-tune for the last 4 years without the added relay with no issues. Just my experience. I am running E85 and my 951 is a track only car, so it is running must of the time at WOT.
Old 03-17-2016, 11:48 AM
theedge
theedge's Avatar
The stock wiring is too small for the 044, there will be a large voltage drop. You should run new wiring and a relay for it. The 044 is also louder, not helped by the fact that you cant really use the stock pump "pill" thing to quiet it down.
Old 03-17-2016, 03:59 PM
rlm328
rlm328's Avatar
I have had no problem running the 044 with the original wiring. It is a different shape than the original pump so you will need to get a different clamp band. Also the suction side to the tank is a bit different. I went with LRs adapter. I had some left over silicon hose that I used to pad the system which helped with the noise created by vibration.
Quick Reply: Bosch 044 Fuel Pump ?'s
