Oil cooler line stuck
Old 02-27-2016, 10:53 PM
Ben Truslow
7th Gear
Ben Truslow's Avatar
Default Oil cooler line stuck
I'm putting a new oil cooler and lines in my car. I can't seem to get the 27mm and 32 mm wrench on and loosen the lower line on the oil filter housing. Looking for any help I can't get! Thanks in advance
Old 02-28-2016, 08:56 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Might need to remove half of the stuff at the bottom to get leverage.
Old 03-01-2016, 01:36 PM
ramius665
ramius665's Avatar
Removing oil lines when they get stuck after years of being secured is a real pain. Liberal use of PB Blaster, letting it soak and then trying again is pretty much the best option. As far as getting the wrenches in there, I'll echo Paul and say you need to remove the power steering pump at a minimum and even then it will be tight. I took full-size 27/32 wrenches and cut them down to be able to get them in there and be able to swing in their range of motion. Using a deadblow hammer on the 32mm wrench helped in breaking things free.
Old 03-01-2016, 10:10 PM
gpr8er
gpr8er's Avatar
crowfoot flare
Quick Reply: Oil cooler line stuck
