Caster block issue
Caster block issue
Hi,
Bought a pair of solid caster blocks from a reputable US vendor, and have an issue. The a-arm has quite some play in it at the caster block. The excentric bolt runs through a sleeve in the block and no matter how much I torque the bolt there is still some play. I would assume that where the bolt runs through the sleeve should be a really tight fit, but it isn't, hence the play and clunky sounds, not to mention the lottery style toe-in/out.. Anyone had experience with this? Bad batch?
BR
Fredrik
BR
Fredrik
