Intake to Port question?
Old 05-23-2015, 06:08 PM
  #31
refresh951
refresh951's Avatar
Very impressive looking Patrick. Like the rail mounts.
Old 05-23-2015, 07:53 PM
  #32
mikey_audiogeek
mikey_audiogeek's Avatar
Originally Posted by 333pg333
Mike it's so far beyond my paygrade that Time separates logic....however, each person that espouses their theory does it with absolute conviction so much so as to convince the working classes that there is no question as to their logic.
Hi Patrick,
Point taken. Theoretical discussions often end up displays of arrogance. My bad.
Have to remind myself that it's better to be good than right!
More positive and constructive comments from me henceforth.
If it turns out that you end up with a maldistribution problem in the plenum, there are some quick/effective/adjustable mods you can make. Hopefully we won't have that conversation.
Cheers,
Mike
Old 05-23-2015, 10:34 PM
  #33
333pg333
333pg333's Avatar
Mike, please don't take my late night ramblings as any form of negativity towards you. I definitely enjoy your input and bow to your tech knowledge and experience. I would prefer people did speak their mind than say nothing. We will tune with Trim and fine tune with EGTs.
Old 05-24-2015, 05:42 AM
  #34
mikey_audiogeek
No worries Patrick, I just have to rein myself in sometimes. I miss playing around with racecars.
Cheers,
Mike
Old 05-24-2015, 07:20 AM
  #35
blade7
blade7's Avatar
Back in the day it was reckoned unequal length headers spread torque over a wider rev range, varioram etc suggests the same applies to intakes.
Old 05-24-2015, 02:23 PM
  #36
Thom
Thom's Avatar
Originally Posted by 67King
For example, if you end up with a 1.62" ID tube which is from a 6800 RPM horsepower number (and adjusted for what kind of tube is available), then you want to hit peak torque somewhere around 5000 RPM, then you'll end up with a runner length (from bellmouth to valve) of about 13" (330mm).
Just for reference this is about the length my intake and Lindsey's use, and that opens up the high rpm breathing big time over the stock intake, with no other mods on the head or 9R camshaft.
Old 05-24-2015, 05:47 PM
  #37
333pg333
333pg333's Avatar
I thought they would have been shorter than that Thom? Interesting. The inner diameter is more like 1.85" on ours for reference.
Old 05-25-2015, 05:42 AM
  #38
Thom
Thom's Avatar
Woops sorry, my memory is playing up. The length my intake and the Lindsey is using is about 220 mm from bellmouth to back of valve.
Quick Reply: Intake to Port question?
