1986 951 for sale, modded, take a look
I have paid my renewal fee for premium membership but it hasnt updated yet.
1986 Porsche 944 Turbo (aka Porsche 951)
Graphite Metallic exterior color with burgundy and black interior.
Clean Indiana title in hand.
VIN: WP0AA0950GN153331
$13,999
(219) 252-4686
First off, I DO NOT need to sell this car but I find that I don’t drive it as much as it should be driven. If it doesn’t sell, it will just be parked in my garage under a cover and I will drive it when I can. This 944 turbo is my show car and is a good example of a clean 944 turbo that turns heads everywhere I go. These cars are getting more unique and more valuable every year as they age. Good examples of them are few and far between. This car is fast and surprises many people who have had the privilege t ride in it or see it in action. I have never tracked the car but it is setup like a track car. I have never launched it off the line or anything abusing like that. There is a lot of money into the car as far as looks and performance. I am only selling as I am buying a house and you have to make compromises in life to achieve other successes.
64,500 miles, slowly climbing as I drive it on nicest days.
Motor/ Trans: New oil pan gasket, oil pickup tube support bracket, oil pan has welded baffle to prevent oil starvation on hard and long left-hand turns, New injectors, fuel pressure gauge on fuel rail, new fuel line in engine bay as well as new damper fuel line, all new front engine seals, new oil pump drive sleeve, aos seals, all new exhaust gaskets on motor and turbo, new cam tower gaskets, new timing and balance shaft belt/rollers, new coil, cap and rotor, new thermostat and fan switch, venturi delete, silicon intercooler hoses, custom front mount intercooler with custom piping, billet diverter valve, all new silicon vacuum lines, rebuilt throttle body, intake manifold gaskets, new idle stabilizer valve, new o2 sensor, pretty much every sensor on motor is new, manual boost controller, SFR 3” downpipe, SFR true 3” cat bypass pipe and SFR 3” catback exhaust (full 3” from turbo to exhaust tip), cat bypass and downpipe are wrapped to help keep temps down, turbonetics stage I turbo(50 trim), autothority stage 2 chips and MAF, new k&n air filter, Vitesse Racing SMT 6 piggyback tuner, wastegate dump to atmosphere (I also have pipe to tie it back in), AEM uego wideband o2, prosport boost gauge, new clutch master cylinder, clutch slave cylinder and line between, oil cooler seals, new oil cooler hoses(upper and lower), 3bar fuel pressure regulator, LR fuel injector w/ knock sensor harness, LR ultra motor mounts, LR solid trans mount, new rear axle, new fuel filter, schnell short shifter, redline trans fluid, mobil 1 engine oil every 2500 miles, new coolant reservoir, power steering delete.
Exterior/ Suspension: Graphite Metallic exterior, paint it is in good shape, rock chips on front end, scratch behind driver side real wheel, a few small dent around car (nothing major). Not original to the car but it does have the optional Turbo sticker on passenger front fender which looks very good. Car has been undercoated with herculiner bed liner to prevent rust. The battery tray has also been coated. Body is straight, Porsche script door handles, windshield is crack / chip free, custom front splitter, front mount intercooler, euro front fog/ driving lights with laminx clear film on them, refinished black brembo brakes, stainless steel braided brake lines front and rear, dot4 brake fluid, front and rear suspension is from '87 year model so it is late offset. front has Koni adjustable struts with adjustable coil sleeves and hypercoil 400# springs as well as adjustable camber plates , rear has torsion bar delete and bilstein turbo cup shocks with hypercoil springs( I have 500# and 700# springs for it). This car is fully adjustable and can be raised and lowered more if wanted. It also has a front strut bar. This car rides like a track car, pretty stiff suspension, not for the faint of heart. Original turbo sway bars front and rear. Depowered steering rack so no leaks. With the wide front wheels, parking lots can be a challenge but it’s not hard to drive. This is also not for the weak people who love the power steering doing everything for you. This car lets you feel and read the road.
Wheels: TR Motorsport F2 wheels. They are wheels built by Enkei for tire rack (TR). They are forged wheels that I bought brand new. The tires mounted on the wheels are the first set of tires mounted on these wheels. I bought the front tires used so they have less tread than the rears. The fronts are 18x10 wide. The rears are 18x11.5 wide. I have 3 other 18x10 wheels brand new still in box to go with car so you could have 18x10’s on all four corners and have a spare wheel. Again, with the 18x10 up front, steering can be hard in parking lots but is fine as long as you are moving. You could source some 18x8 wheels for the front to help this problem a lot. The rear tires on the 18x11.5 have a lot of tread but the tires have been stretched on the stretched on the wheel so help with rubbing on body.
Interior: Burgundy interior with rare partial leather Porsche recaro scripts seats. Dash is also the rare all leather option dash. Driver side is full power and passenger is manual adjusting, Momo Mod 7 350mm leather steering wheel with hub and working horn button, Lloyds turbo mats, pioneer avh-p4900dvd headunit with ipod/iphone 4s or older hook up, all new speakers, wires are ran for sub or amp in truck but I never hooked anything up. Bolt in rear roll/ harness bar. No holes in body as it bolts to rear seat belt location. AEM uego wideband gauge, boost gauge, and manual boost controller are mounted below radio. Heats work well, a/c does not work and I wouldn’t use if it did, I love having the windows down. Sunroof is power but does not work with power but does work manually if you want to remove it. All other accessories work. The rear hatch has some separation of glass to frame with is very common, just letting you know. Dash also have crack in it but is far from the work I have seen.
Conclusion: This car is a blast to drive and it rewards you every time you drive it. It turns heads everywhere and sounds amazing. It is also pretty fast for how old it is and will keep up with many quick cars made today. The build quality of these cars are why they are still on the road today. The sound of the doors when you shut them is one example of this. As years go on, these cars get more and more rare and it gets harder to find a good example like this.
Note most pictures do not have the rollbar or front lip as they are more recent.
$13,999
(219) 252-4686
996 turbo front splitter, make a few relief cuts and shorten ends. Use heat gun to melt/ help bend splitter as its urethane.
http://www.ebay.com/itm/01-05-Porsch...2b30fc&vxp=mtr
Ahhh Dan's old car... I am in love with this thing...
This car is so beautiful, I tried to track it down before I bought my 951. Maybe I contacted you, but something didn't work out.
Wish I had the cash now!
