Turbocharger Compressor and Turbine Maps Mega Thread
Old 01-17-2015, 09:04 AM
Kris H
Kris H's Avatar
Thumbs up Turbocharger Compressor and Turbine Maps Mega Thread
I woke up today and thought about all the compressor maps I came across last few days when calculating my build. These are very useful and as far as I know, there is no thread in here that compiles all the maps, so the time has come to change that. Here's the list of turbo and supercharger's maps I found so far:
BorgWarner
<place reserved - will update later>
EATON Superchargers
Maps:
EATON m45 inlet flow
EATON m45 power chart
EATON m45 delta temperature
EATON m62 inlet flow
EATON m62 power chart
EATON m62 delta temperature
EATON m90 inlet flow
EATON m90 power chart
EATON m90 delta temperature
EATON m112 inlet flow
EATON m112 power chart
EATON m112 delta temperature
Garrett
Compressor maps:
Garrett T3-40
Garrett T3-45
Garrett T3-50
Garrett T3-60
Garrett T3-Super 60
Garrett T04B-60-1
Garrett T04B-62-1
Garrett T04B-H3
Garrett T04B-S3
Garrett T04B-V1/V2
Garrett T04E-40
Garrett T04E-46
Garrett T04E-50
Garrett T04E-54
Garrett T04E-57
Garrett T04E-60
Garrett T04 housing 76mm, 52 trim, 0.70 A/R
Garrett T-61
Garrett T-64
Garrett T-66
Garrett T-68-1
Garrett T-70
Garrett T-72
Garrett T-76
Garrett GT12 41mm, 50 trim, 0.33 A/R
Garrett GT15 45mm, 60 trim, 0.48 A/R
Garrett GT20 56mm, 55 trim, 0.53 A/R
Garrett GT22 52mm, 60 trim, 0.51 A/R
Garrett GT22 59.4mm, 52 trim, 0.42 A/R
Garrett GT25R 54.3mm, 60 trim, 0.80 A/R
Garrett GT2540R 76mm, 48 trim, 0.70 A/R
Garrett GT28R 60mm, 60 trim, 0.60 A/R
Garrett GT28RS 60mm, 62 trim, 0.6 A/R
Garrett GT30R 76.2mm, 56 trim, 0.60 A/R
Garrett GT30R 71mm, 56trim, 0.50 A/R
Garrett GT32 71mm, 52 trim, 0.52 A/R
Garrett GT35 71mm, 52 trim, 0.50 A/R
Garrett GT35 76mm, 52 trim, 0.50 A/R
Garrett GT35R 68mm, 56 trim, 0.70 A/R
Garrett GT37 76mm, 52 trim, 0.54 A/R
Garrett GT37 82mm, 52 trim, 0.54 A/R
Garrett GT40 88mm, 54 trim, 0.72 A/R
Garrett GT40 82mm, 50 trim, 0.58 A/R
Garrett GT42 94mm, 56 trim, 0.60 A/R
Garrett GT42 102mm, 53 trim, 0.60 A/R
Garrett GT60 141mm, 56 trim, 1.05 A/R
Turbine Maps:
Garrett GT12, 72 trim, 0.39 A/R turbine map
Garrett GT15, 72 trim, 0.35 A/R turbine map
Garrett GT20, 72 trim, 0.46 A/R turbine map
Garrett GT22, 72 trim, 0.67 A/R turbine map
Garrett GT22, 72 trim, 0.56 A/R turbine map
Garrett GT25R, 62 trim, 0.64 A/R turbine map
Garrett GT28R, 62 trim, 0.64 A/R turbine map
Garrett GT28RS, 76 trim, 0.86 A/R turbine map
Garrett GT28RS, 76 trim, 0.64 A/R turbine map
Garrett GT30R, 84 trim, 1.06 A/R turbine map
Garrett GT30R, 84 trim, 0.82 A/R turbine map
Garrett GT3071R, 84 trim, 1.06 A/R turbine map
Garrett GT3071R, 84 trim, 0.82 A/R turbine map
Garrett GT3071R, 84 trim, 0.63 A/R turbine map
Garrett GT32, 73 trim, 0.78 A/R turbine map
Garrett GT32, 73 trim, 0.69 A/R turbine map
Garrett GT35, 84 trim, 1.18 A/R turbine map
Garrett GT35, 84 trim, 1.05 A/R turbine map
Garrett GT35, 84 trim, 0.94 A/R turbine map
Garrett GT35, 84 trim, 0.67 A/R turbine map
Garrett GT35R, 84 trim, 1.06 A/R turbine map
Garrett GT35R, 84 trim, 0.82 A/R turbine map
Garrett GT37, 84 trim, 1.12 A/R turbine map
Garrett GT40, 84 trim, 1.34 A/R turbine map
Garrett GT40, 84 trim, 1.19 A/R turbine map
Garrett GT40, 73 trim, 0.94 A/R turbine map
Garrett GT42, 84 trim, 1.28 A/R turbine map
Garrett GT42, 84 trim, 1.15 A/R turbine map
Garrett GT42, 84 trim, 1.01 A/R turbine map
Garrett GT60, 84 trim, 1.70 A/R turbine map
Garrett GT60, 84 trim, 1.47 A/R turbine map
Garrett GT60, 84 trim, 1.25 A/R turbine map
Holset
"full" compressor maps:
Holset HX30E-7765AX
Holset HX30E-7755AX
Holset HX40V-C8579M
Holset HX40-B8554M (8-blade)
Holset HX40-B8574M (7-blade)
Holset HX40-B8574M vs 8284AD
Holset HX40-B8584M (6-blade)
Holset HX40-B8584M with 127660 curve
Other maps:
Holset HE200
Holset HE300
Holset HE351 (lb/min)
Holset HE351
Holset HE351VE (no islands)
Holset HE351CW-Y8597BS vs HY35W-E7765AX vs HX35W-XXXXXXX (no islands)
Holset HE400
Holset HE431 VTG
Holset HE500
Holset HX20
Holset HX25-27
Holset HX35
Holset HX35 (CFM)
Holset hx35 8-blade map
Holset Hx35(green), HE351 (red), "New Hy35" (black) (no islands, CFM)
Holset HX35-40 hybrid
Holset HX40 vs Super40 (no islands, metric flow)
Holset HX40 vs Pro 52 (no islands, metric flow)
Holset HX40 vs Super HX40 vs Super 52 (no islands, metric flow)
Holset HX40 vs Super HX40 vs Super 52 (no islands)
Holset HX40 vs Super40 vs Pro52 (no islands)
Holset HX50
Holset HX52
Holset HX55
Holset HX60
Holset HX82-83
Holset HY35
Holset H1E
Holset WH1E
KKK
Compressor maps:
KKK K03-1870
KKK K03-2072
KKK K04-0025 ?
KKK K04-2078
KKK K14-2464
KKK K16-2467
KKK K24-2470
KKK K26-2664 on Audi 100t engine
KKK K26-2470 on 924t engine
KKK K24-2672 on Audi RS2
Mitsubishi
Compressor maps:
Mitsubishi TD04 09B
Mitsubishi TD04 13G
Mitsubishi TD04 15G
Mitsubishi TD04H 18T
Mitsubishi TD05 14B
Mitsubishi TD05 14G
Mitsubishi TD05 16G large
Mitsubishi TD05 16G small
Mitsubishi TD06 17C
Mitsubishi TD06 20G
Mitsubishi TD06 20g
Mitsubishi TS04
Precision
<reserved - will update later>
Vortech Superchargers
sources:
http://s4wiki.com/wiki/Category:Compressor_maps
https://www.rbracing-rsr.com/turbosupermaps.html
http://forums.turbobricks.com/showthread.php?t=120156
http://s484.photobucket.com/user/whe...?sort=3&page=1
http://www.dieseltruckresource.com/f...ied-up-255049/
http://www.bimmerforums.com/forum/sh...X35-M50NV-3-0L
Old 01-17-2015, 09:05 AM
Kris H
Kris H's Avatar
Tutorial - compressor map basics
<place reserved for tutorial - will update later>
Kris H
Kris H's Avatar
Tutorial compressor maps pt2
Old 01-17-2015, 09:14 AM
Kris H
Kris H's Avatar
Tutorial 3
Old 01-17-2015, 09:02 PM
eman930
eman930's Avatar
I'm excited to get my learn on
Old 01-18-2015, 11:07 AM
blown 944
blown 944's Avatar
Thanks for putting in the time. It'll be easier now to research.
Old 01-18-2015, 06:53 PM
t3rra
t3rra's Avatar
Be cool if someone in the know could plot out the stock head/engine on some off the most popular turbos.
Quick Reply: Turbocharger Compressor and Turbine Maps Mega Thread
