Help ID part
Old 10-28-2014, 06:23 AM
Thom
Thom's Avatar
Default Help ID part
Hi everyone,
Can someone please confirm the part number for the white T connector circled in red?
When it's not broken it's normally linked to the Y connector on the left side for the heater control, with the usual blue/black check valve in between.
Looking at PET I would say it's part number 321 611 813 (t-socket, not illustrated), but would appreciate confirmation.
Thanks.
Old 10-29-2014, 12:12 AM
mel_t_vin
mel_t_vin's Avatar
Thom, is the connector you have circled in red not #18 in the diagram, 067 133 753 A, where the split would go to the blue/black check valve?
Old 10-29-2014, 07:57 AM
931guru
931guru's Avatar
The original poster is right...
http://www.autoatlanta.com/Porsche-D...321611813.html
Old 10-29-2014, 08:27 AM
mahoney944
mahoney944's Avatar
A venturi delete does away with that connector
Old 10-29-2014, 06:01 PM
mel_t_vin
mel_t_vin's Avatar
Taking another look at the diagram, I agree with you. Makes sense, as #18 is labeled, Venturi Tube. That splitter [I mis-identified] actually resides under the IM, and the hose from its "split" goes to the "split" in the other venturi tube that connects the IM to the ICV.
Thom, appears your assessment was correct all along.
Quick Reply: Help ID part
